It is currently Tue Nov 10, 2026 8:00 am
 Post subject: Tip! Don't stroke the selection, stroke the path - video
PostPosted: Tue Apr 13, 2010 7:59 pm  (#1)
 Post subject: Re: Tip! Don't stroke the selection, stroke the path - video
PostPosted: Wed Aug 14, 2013 2:15 pm  (#2)
Hello There
Great stuff thanks... :bigthup Can I use the same technique with the paintbrush tool too?
Thanks RalphC
PostPosted: Wed Aug 14, 2013 2:26 pm  (#3)
Ralphc wrote:
Hello There
Thanks RalphC
Welcome to Gimp Chat. :)
Yes you can. Just select stroke with paint tool and the brush will stroke the path instead of using the default stroke with line option.
PostPosted: Fri Aug 16, 2013 1:13 pm  (#4)
Hi Rod...
Thanks for the welcome :) That's good news 'bout the Paint Brush. Finding these 'Tut's' very, very useful. Great resource. Appreciate all the hardwork contributors put into these. :tyspin
Best wishes
RalphC
PostPosted: Fri Aug 16, 2013 1:36 pm  (#5)
Hi Again...
Silly Q coming here :oops: Tried the 'Select to Path' with a straight line...Can't seem to get it to work. Does it have to be a circle, Box, oblong etc. for this feature to work? Got a great Rivet effect BTW using the circle and paint brush ;)
Thanks
RalphC
PostPosted: Fri Aug 16, 2013 1:51 pm  (#6)
Ralphc wrote:
Hi Again...
Thanks
RalphC
The selection must be closed. :)
To create a straight line try selecting any paint tool, clicking once on the image window and holding down the shift key. Click again where you want your line to end. You can do this with any paint tool. :bigthup
PostPosted: Fri Aug 16, 2013 1:56 pm  (#7)
alpha to selection on our object you want to stroke.
pick what brush you are going to stroke with use the spacing to set your stroke
selection to path
select none
go to path dialogue
paint along path with brush.
PostPosted: Fri Aug 16, 2013 2:02 pm  (#8)
selection to path
select none
go to path dialogue
You can do some really cool stuff with straight lines and Filters>Map>Map-Object. :)
PostPosted: Sat Aug 17, 2013 3:00 am  (#9)
Thank you both for your responses.
As usual very helpful. I'm on a bit of a steep learning curve with GIMP (no pun intended) so all help is appreciated. :bigthup
I Actually use GIMP for repainting aircraft in the colours of airlines (usually older airlines) for Flight Simulator 9 and Flight simulator X. It's excellent. There are certain things though that I need to learn to get the best effects to ensure accurate reproductions. Hence the Q's. The metal effects tutorials are particularly relevant and very useful. Not sure if it's appropriate to 'post' some of my 'work here though :)
Having read some of the Tuts here though, I'm keen to branch out and produce some 'Artwork.' The examples I've seen are awesome! :)
I'll keep practicing and reading.
Thanks Again
RalphC :bigthup
PostPosted: Sat Aug 17, 2013 8:49 am  (#10)
Thanks Again
RalphC :bigthup
You are most welcome. Anything we can help you with just holler at someone. :)
cron
