It is currently Wed Nov 18, 2026 8:42 am
Post new topic Reply to topic  [ 76 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: How I Create a Spiro Lines Design
PostPosted: Sat Jan 17, 2015 2:59 pm  (#1)
This video will show you how I create spiro type line designs, similar to the image seen below.
 Post subject: Re: How I Create a Spiro Lines Design
PostPosted: Sat Jan 17, 2015 3:11 pm  (#2)
Nice one Wallace :bigthup
I like the way you include the different scenarios.
PostPosted: Sat Jan 17, 2015 3:36 pm  (#3)
Thanks Odin. :bigthup
I had issues with the brush size I was using when I first started using the stroke/fill visible paths script. I thought it would be a good idea to show what might happen if the selected brush was too large or left at default.
PostPosted: Sat Jan 17, 2015 5:40 pm  (#4)
Nice videos, you always explain everything so well.
PostPosted: Sat Jan 17, 2015 5:42 pm  (#5)
You get cleaner results by merging the visible paths and stroking the single resulting path in 'line" mode. Line mode gives cleaner results than stroking with a paintbrush which is all you can do in a script.
PostPosted: Sat Jan 17, 2015 5:50 pm  (#6)
Thanks 2-ton. :hi5
I do all my videos by the seat of my pants or on the fly, so to speak. I'm not a pro at this, but I think I get my point across pretty well, most of the time anyway.
That's a good point Ofnuts. ;) I think I did show that, but I'm not sure.
PostPosted: Sat Jan 17, 2015 8:16 pm  (#7)
Well, this is curious. One of the scripts is available in Gimp scripts and source forge but the other one is only available on source forge.
boo, I got both scripts in my python folder but I can't call it up. I don't have the "tool" option when I right click on the path. Darn OS X, always has to be difficult.
PostPosted: Sat Jan 17, 2015 8:22 pm  (#8)
I have no idea why that is. That's a question for Ofnuts to explain.
PostPosted: Sat Jan 17, 2015 11:49 pm  (#9)
Another good one.
PostPosted: Sun Jan 18, 2015 12:11 am  (#10)
Nice tutorial Wallace, I can see this being something I'll enjoy exploring.
I've had a quick play...
Used this script Path Blend to generate a gradient between the original paths, its slow but very good.
PostPosted: Sun Jan 18, 2015 2:07 am  (#11)
OK Wallace, I have now viewed your excellent tutorial again to reinforce the fine points therein and completed my first serious attempt at replicating your spirals, deftly following your instructions.Then added some tweaks - artistic license!
Thanks again Wallace - love learning from you.
PostPosted: Sun Jan 18, 2015 12:15 pm  (#12)
Nice work you guys! :jumpclap
@He4rtyI... Really love the colors and the angles in your work. :bigthup
@OMG... Your a quick study. ;)
PostPosted: Sun Jan 18, 2015 2:25 pm  (#13)
Wow that is a good one Wallace, I don't know how I missed this one. I think I should be able to do that rather than they other way you showed me. Thanks for sharing.
PostPosted: Sun Jan 18, 2015 2:29 pm  (#14)
Sure thing Molly. :bigthup
Show us what you can do! :jumpclap
PostPosted: Sun Jan 18, 2015 2:43 pm  (#15)
probably end up like a donut or something. I noticed you used the pencil for your stroke. instead of the brush.
PostPosted: Sun Jan 18, 2015 2:46 pm  (#16)
Been playing some more, mainly using the lighting effects filter with bump maps and environment maps enabled as described in this tutorial "Environment Mapped Text Tutorial", I mapped an area the size of the largest square and then used the line design as a layer mask.
PostPosted: Sun Jan 18, 2015 3:08 pm  (#17)
Cool looking image! :bigthup
Those are some really nice ideas you have there.
PostPosted: Sun Jan 18, 2015 3:11 pm  (#18)
No... I used a 1x1 brush for the stroke not the pencil tool . In the video... I only clicked on the pencil tool to get out of the paths dialog, so I could start the second path.
PostPosted: Sun Jan 18, 2015 3:11 pm  (#19)
Thanks for the compliment Wallace :bigthup
PostPosted: Sun Jan 18, 2015 3:14 pm  (#20)
