It is currently Wed Nov 18, 2026 8:03 am
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2, 3  Next
 Post subject: EZ 3D Text
PostPosted: Tue Mar 10, 2015 6:10 pm  (#1)
Here's a chart I made showing some of the various 3D extrusions and the corresponding direction to use.
The extrusion depth used in this image was set to 8, with a drop shadow added.
 Post subject: Re: EZ 3D Text
PostPosted: Wed Mar 11, 2015 1:48 am  (#2)
Wallace thanks for posting this tutorial on 3d text
PostPosted: Wed Mar 11, 2015 2:40 am  (#3)
No problem. :bigthup
I thought of making the video more involved. By showing a fully comprehensive use of the 3D Extrusion script, but decided against that.
My thinking for this was, that simple would be better. My feeling is, that most people are looking for simple, as apposed to long-winded/fully comprehensive video anyway.
It's uncomplicated and for the most part straightforward in it's presentation. The title says it all, EZ 3D Text and that's what I think I've demonstrated.
PostPosted: Wed Mar 11, 2015 4:56 am  (#4)
Very nice Wallace, as usual, well explained.
PostPosted: Wed Mar 11, 2015 11:10 am  (#5)
I forgot I had it. :oops:
Done with a pattern
PostPosted: Wed Mar 11, 2015 4:13 pm  (#6)
Thanks you guys, glad you all in joyed it.
PostPosted: Thu Mar 12, 2015 5:59 am  (#7)
You have. Thank you :bigthup
PostPosted: Thu Mar 12, 2015 7:24 am  (#8)
PostPosted: Thu Mar 12, 2015 9:26 pm  (#9)
Hi guys - just watched the vid (thanks Wallace) and tried out a number of different directions ... no problems here ...
PostPosted: Thu Mar 12, 2015 9:50 pm  (#10)
That looks really great OMG. :bigthup
PostPosted: Fri Mar 13, 2015 1:29 am  (#11)
Cheers Wallace :bigthup
PostPosted: Fri Mar 13, 2015 7:45 am  (#12)
Wallace, your tut is very easy to follow and the outcome is perfect.
PostPosted: Fri Mar 13, 2015 8:38 am  (#13)
Online
Wallace
as you can see, it works perfectly now
in orde.xcf [1.91 MiB]
Downloaded 300 times
PostPosted: Fri Mar 13, 2015 9:59 am  (#14)
Cheers to you as well Odin. Image
Thanks Carlos Diniz, that was the plan after all. :D
gimper66 wrote:
Wallace
Glad you got it going. Nice text images too. :bigthup
PostPosted: Fri Mar 13, 2015 1:44 pm  (#15)
Online
gimpchat.xcf [2.83 MiB]
Downloaded 290 times
PostPosted: Fri Mar 13, 2015 5:09 pm  (#16)
gimper66 wrote:
Nice one Gimper66. :bigthup
PostPosted: Sat Mar 14, 2015 4:19 am  (#17)
Ah, an intertwined doodled 3d extrusion ...
PostPosted: Sat Mar 14, 2015 5:16 am  (#18)
Hehehe Oldmangrumpy, you are so versatile. Great outcome.
Gimper, good for you. You could repair the problem. Good outcomes.
PostPosted: Sat Mar 14, 2015 7:48 am  (#19)
tried a line drawing. didn't work as well
With textured glass
PostPosted: Sat Mar 14, 2015 7:53 am  (#20)
Well done Sallyanne, specially the glass one . I like oldmangrumpy's intertwined idea a lot. Nice outcomes. :bigthup
