It is currently Tue Nov 10, 2026 8:19 am
 Post subject: Screen Shot? - Video tutorial
PostPosted: Fri Feb 25, 2011 3:33 pm  (#1)
Link to the stock image:
http://superstar-stock.deviantart.com/a ... loggedin=1
 Post subject: Re: Screen Shot? - Video tutorial
PostPosted: Fri Feb 25, 2011 4:00 pm  (#2)
Clever! Thanks, Jolie! :)
PostPosted: Fri Feb 25, 2011 5:03 pm  (#3)
Very interesting. I think if my picture had darker colors it would look better. It was fun!
PostPosted: Fri Feb 25, 2011 5:08 pm  (#4)
O, you could always add another layer with black background and reduce the opacity til it gives you that refractive look.
Just for the glass area, not the entire image.
PostPosted: Fri Feb 25, 2011 6:48 pm  (#5)
Former Member
Nicely done Julie!
PostPosted: Fri Feb 25, 2011 9:09 pm  (#6)
Lol, very funny...and also a great tutorial!
PostPosted: Fri Feb 25, 2011 10:22 pm  (#7)
I'll have to start over. I didn't save it as an xcf file.
PostPosted: Fri Feb 25, 2011 11:32 pm  (#8)
Great tutorial Jolie, thanks for sharing it. :)
PostPosted: Sun Feb 27, 2011 12:11 pm  (#9)
Great idea to use it on a picture frame O. :mrgreen:
When I was trying this out I tried different backgrounds, and different broken glass images and found that sometimes you need to do some color corrections on the picture layer too.
Some more broken glass images:
http://browse.deviantart.com/?q=glass&o ... 24#/d6nxlh
PostPosted: Sun Feb 27, 2011 12:30 pm  (#10)
very nice tutorial Jolie
PostPosted: Sun Feb 27, 2011 12:35 pm  (#11)
I tried mahvin's suggestion. It does help.
PostPosted: Sat Jul 30, 2011 9:12 pm  (#12)
another splash image to test out this shattered glass thing.
this took a bit of time......and while I was changing the blend mode to overlay I thought, what if I did a color to alpha? my particular glass image (which I think I grabbed from flickr) was all black background.
that worked and really looks the same as changing the blend mode but kinda looked a bit flat so i duplicated the layer and ran the glass script because I figured that could add a shadow layer that would help give it a better 3D look.
there's a bunch of other layers but what one does really has more to do with the original glass image. Sure learned a few things doing this.
PostPosted: Sat Jul 30, 2011 9:16 pm  (#13)
Cecilia, that looks so good. Like real, broken/shattered glass. Excellent job!
PostPosted: Sat Jul 30, 2011 11:23 pm  (#14)
thanks
I spent some time looking for suitable glass....one of these is this image
radiate by ~My aim is true~, on Flickr
but I think the main 'trick' is realizing that glass - and especially broken glass - has all sorts of reflections and refractions. suggesting that with several layers fools the eye.
