It is currently Tue Nov 10, 2026 8:57 am
 Post subject: Make an Apocalyptic Scene Using Gimp
PostPosted: Mon Aug 10, 2015 2:36 pm  (#1)
This 60-minute lesson (or if you're in a hurry, there is a 5 minute version, too) shows every step of how I made this image, and will enable you to do the same
Final Image:
Original Tutorial (60 minutes long)
Speed Run (5 minutes long)
The original Tutorial with source files and credits can be found Here.
 Post subject: Re: Make an Apocalyptic Scene Using Gimp
PostPosted: Mon Aug 10, 2015 4:28 pm  (#2)
Nice one, tstandiford.
PostPosted: Mon Aug 10, 2015 8:34 pm  (#3)
:coolthup
PostPosted: Tue Aug 11, 2015 9:12 am  (#4)
not the kind of stuff i usually make, but i like the result and i suspect the tutorial contains some new tricks for me, so i might give it a go after all. thanks for sharing!
PostPosted: Wed Mar 09, 2016 6:47 pm  (#5)
I like it but it's still too hard for me :bigthup
PostPosted: Wed Mar 09, 2016 7:53 pm  (#6)
Links are not working and images not showing. I am interested in this tutorial.
Faith that no works is not faith at all.
PostPosted: Wed Mar 09, 2016 8:09 pm  (#7)
Have you clicked on the Show Spoiler links? If they are not working, your browser might be blocking them. You're right about the bottom 'Here' link it's not working.
PostPosted: Fri Mar 11, 2016 1:35 am  (#8)
The overall image and effects look really good, but the band on the left arm doesn't look like it is on her arm. I watched the 5 minute version of the tutorial without sound, as I am at work, so I did not hear you, but it just doesn't look natural.
