It is currently Tue Nov 10, 2026 7:21 am
 Post subject: How to Manually posterize an image in GIMP
PostPosted: Mon Sep 11, 2017 4:34 pm  (#1)
Script mentioned in video: script link available on gimplearn.net
 Post subject: Re: How to Manually posterize an image in GIMP
PostPosted: Mon Sep 11, 2017 8:55 pm  (#2)
That's pretty cool! Can the same effect done without the script, my mcgimp doesn't do most python scripts.
PostPosted: Mon Sep 11, 2017 9:31 pm  (#3)
The scripted effect is based on this tutorial:
http://gimp-science-labs.blogspot.de/20 ... ation.html
Trandoductin just forgot to give credit.
And btw, mr. 2-ton, you are a subscriber to this very blog.
PostPosted: Mon Sep 11, 2017 9:43 pm  (#4)
I always try to refer which site the script is based of off.
In my script link where the script is actually found. The very first thing i do is point to the tutorial.
PostPosted: Tue Sep 12, 2017 4:49 pm  (#5)
And I would like to try out your new plugins.
Was deleted because the effect is a bit different than expected by the author of the guide?
Remember forever - creating plugins is more than writing guides.
All your plugins are inspirational - and you can always modify them according to the suggestions of those interested.
I salute You and admire the development of your website:
https://www.gimplearn.net/
ps. Like many of us, I was absent for a while from the Forum - God will return to this forum and life.
PostPosted: Tue Sep 12, 2017 10:52 pm  (#6)
Thanks, and yes, I do believe I subscribed to this blog a long time ago. I have always like Esper's tutorials. They teach every step needed to do an effect manually. I do miss his input to gimpchat, there is just not enough time to go and check out all the other sites/blogs!
