It is currently Tue Nov 10, 2026 8:57 am
 Post subject: Using Mathmap Distort Wave to Bend Mask Lines
PostPosted: Mon Jun 13, 2011 6:01 pm  (#1)
It's by the far the easiest method I've come across so far, taking me less than one minute to achieve.
Best viewed in full screen and on Youtube:
 Post subject: Re: Using Mathmap Distort Wave to Bend Mask Lines
PostPosted: Mon Jun 13, 2011 6:18 pm  (#2)
That is a very good find mahvin. Works great!!!!......
PostPosted: Mon Jun 13, 2011 6:33 pm  (#3)
Excellent! :)
PostPosted: Tue Jun 14, 2011 2:43 am  (#4)
soooo obviously..I dont have mathmap....or a number of other features in the generic range of filters.....where might these be found
PostPosted: Tue Jun 14, 2011 3:24 am  (#5)
akky, I have some very good instructions that another member did for me a year or so ago and they have all the links and step by step how to install Mathmap. I will ask for permission to post them if no one gets back to you first.
PostPosted: Tue Jun 14, 2011 3:26 am  (#6)
Akky, check your PM, too.
Maybe Molly's friend has a better version than the link I provided you with, but it needs to be for a Mac OS X.
PostPosted: Tue Jun 14, 2011 3:36 am  (#7)
Akky, what OS are you using? The instrucs I have are for windows
PostPosted: Tue Jun 14, 2011 3:38 am  (#8)
Akky uses a Mac.
PostPosted: Tue Jun 14, 2011 3:42 am  (#9)
Mac OS X 10.6.7
PostPosted: Tue Jun 14, 2011 3:45 am  (#10)
okay, I guess my instrucs won't help then, sorry...
PostPosted: Tue Jun 14, 2011 5:26 am  (#11)
nope but thanks anyway
