It is currently Fri Nov 13, 2026 9:00 am
 Post subject: Colorful Glowing Text Effect [Video and Written Tut]
PostPosted: Thu Jun 23, 2011 8:50 pm  (#1)
Make sure you watch in 1080p
Original Tut Here:
http://www.tutorial9.net/tutorials/phot ... ng-text-...
Written Tutorial
Step 1
New 800x600 (doesnt really matter).
Fill with a dark violet.
Step 2
Add Text. Have each letter a seperate text layer. You should use white so you can see wherer it is more clearly(unlike the video where i used black text...oops)
Step 3
Align Text with the align tool. Center it vertically then use the move tool and move it left or right, pixel by pixel with the arrow keys.
Step 4
Add a new transparent layer and with your gradient tool, go white to transparent, top to bottom.
Step 5
Cutout the Letters using this process
1.Alpha to selection on one letter.
2.Go to the Gradient layer (while still maintaining the selection)
3.Click Copy and then paste.
4.Set the pasted area as a new layer.
5.Repeat for each layer
(In this screenshot, turned the visibility off my original text layers)
Step 6
Delete All the other layers except for the new cutout letters and the background. Unfortunately unlike the photo below, you should have seperate layers for the letters. I accidently merged them when i took the screenshot but i undid it and continued the tutorial. The image should look like this, just ignore the layer dialogue box.
Step 7
Add color to your letters. Alpha to selection each layer and fill in any color (choose light colors) with the fill tool. OR like in the video, lock the alpha channel then fil or drag and drop from the forground and background picker.
Step 8
Turn off the visibility on the background layer and merge visible layers.
Step 9
Duplicate your colored letters now. On the bottom one, apply a gaussian blur of 10px.
Step 10
On that blurred text, apply a motion blur with these settings.
Step 11
Repeat step 10 but with the angle at 180.
Step 12
Add a reflection using this process.
1.Duplicate the text
2.Flip Vertically
3.Move down using arrow keys to the base of the original text
4.Add a layer mask(white)
5.Use the gradient tool from black to transparent and go fromt bottom to top of the text (not the whole layer)
6.Apply layer mask
7.Lower opacity to 50ish
Also, duplicate the text 3 or so times and set their modes to overlay. Keep the original text layer at normal mode.
Step 13
Add some final touches to the background. New transparent layer above the background. Use a white to transparent gradient (radial) and go from center outwards. Set to overlay. Duplicate.
Step 14
Flatten Image.
 Post subject: Re: Colorful Glowing Text Effect [Video and Written Tut]
PostPosted: Thu Jun 23, 2011 9:03 pm  (#2)
Very pretty results. Also, very nice of you to do a written tutorial along with your video tutorial.
I love the way the text glows.
PostPosted: Thu Jun 23, 2011 9:17 pm  (#3)
Well my last tutorials seemed to be a bit hard to follow so i decided to show how the tutorial is done and tell how its done so its easier to follow along.
PostPosted: Thu Jun 23, 2011 9:18 pm  (#4)
You can also desaturate your text a bit after step 8 to allow the letters to show through eachother
PostPosted: Thu Jun 23, 2011 9:31 pm  (#5)
Love the results, I'll give it a try!
PostPosted: Thu Jun 23, 2011 9:42 pm  (#6)
Please show me your result!
PostPosted: Fri Jun 24, 2011 12:21 am  (#7)
I decided to add some stars. I think I put stars in everything I do... :P
Is it just me, or does saving and/or uploading degrade the quality a little? I swear the radial gradient part in the middle looked a lot smoother in GIMP. Grr.
PostPosted: Fri Jun 24, 2011 8:09 am  (#8)
JFish, I wanna see a tut for your sig ;)
Or did I miss it
Woops just haven't read it yet ;) going to give it a try :bigthup
I'm back I think
PostPosted: Fri Jun 24, 2011 10:01 am  (#9)
Very pretty Amanda.
Could be the browser or Internet.
Something you may want to try ... when I want to check how an image looks without having the window "dressings" around it is click Filters > Animation > Playback and click the detach button in the playback dialog. Then click on the webpage where the image is and you can compare the two. You can move the detached picture around. This way you have the advantage of your image still being in GIMP.
