It is currently Thu Nov 12, 2026 5:35 am
 Post subject: Fun Glass Effect Tutorial and others
PostPosted: Wed Aug 24, 2011 10:40 am  (#1)
Hi everyone, I did my first tutorial on YouTube. The first one I did is the Glass Effect tutorial.
I'll admit I don't think the video is all that great and I'm just now learning how to make screen videos.
I'll get better at it as I do more and learn more about the editing and the screen recording program
Blueberry Flash Back. Well I hope you like and here is the links to the tutorials.
http://www.youtube.com/user/ZioDeMaluir ... kQOwHyltoI
and
http://www.youtube.com/user/ZioDeMaluirs?feature=mhee
There are two parts to this tutorial. Sorry, I forgot to mention this. Both are on Youtube.
 Post subject: Re: Fun Glass Effect Tutorial and others
PostPosted: Wed Aug 24, 2011 2:41 pm  (#2)
I did the first tutorial. Interesting. Although downloading the Stars in the Sky script was in the tutorial, it wasn't used in the tutorial. Perhaps a later tutorial?
PostPosted: Wed Aug 24, 2011 2:59 pm  (#3)
That looks Awesome Oregonian
and the second part of the tutorial is here
Sorry I have to look at those links I think i did them wrong.
By the end of the tutorial you will use the other stars.
PostPosted: Wed Aug 24, 2011 6:44 pm  (#4)
I subscribed! :)
Good tutorials and i am looking forward to more.
PostPosted: Thu Aug 25, 2011 10:45 am  (#5)
I love the script but I could not get enough color for my purposes so I did the following:
I kept the original layer and selected alpha to selection
I created a New layer (blue)>invert>edit>cut>invert >select none
I set the new layer opacity to about 30 and set the mode to soft light
I guess you could play around with the layer mode and opacity to get the desired results. Depends on how dark your background is.
Thoughts?
PostPosted: Thu Aug 25, 2011 2:44 pm  (#6)
@Rod,thank you and it won't be too long before I do another one. :)
@Draconian, to get the color I want, I sometimes will duplicate the color layer and then go to the mode and hit multiply or I will go into the colors and mess with the curve and then go back to messing with the modes. I like the way you did the glass text :). I wanna try something with how you did the (blue)>invert>edit>cut>invert >select none . I think you gave me idea for something. But I will post after I do this other tutorial and help all three of my kids with their homework. I love the way the blue sets off the edges and makes it look like real glass. Great Job :)
