It is currently Tue Nov 10, 2026 8:21 am
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: Metallic Text run thru
PostPosted: Wed Sep 14, 2011 11:46 pm  (#1)
Well, here's a quick run thru of how I did the metallic text. Maybe someone finds it helpful.
http://www.youtube.com/watch?v=vrGRjUXa8UM
 Post subject: Re: Metallic Text run thru
PostPosted: Wed Sep 14, 2011 11:55 pm  (#2)
Thanx for the vid Nixnine. :)
PostPosted: Thu Sep 15, 2011 10:41 pm  (#3)
This is a very nice tutorial. I did mine with bronze instead of copper but I tried copper, blue steel and gold while I was at it. I debated about the second layer at multiply mode but went ahead and did it.
I didn't have as good of luck with smaller sizing. The bevel needs to be adjusted more than I adjusted it. I made the width 20 and the depth 15. Venus Rising font size is 80.
PostPosted: Thu Sep 15, 2011 10:53 pm  (#4)
They both look good O. :)
The bottom one looks like it has a reflection in it.
PostPosted: Thu Sep 15, 2011 10:56 pm  (#5)
Thanks, Rod.
Although it doesn't show it, the top one is much larger than the image in here. Click on it to see it full sized.
PostPosted: Thu Sep 15, 2011 11:12 pm  (#6)
3600x568 i would say that is pretty darn huge. :lol
PostPosted: Thu Sep 15, 2011 11:13 pm  (#7)
I used the tutorial settings. I don't think I'd ever have a need for an image that large.
PostPosted: Fri Sep 16, 2011 12:04 am  (#8)
I make them large then scale them down to a more convenient size after. Seems to retain the quality better. I also blow-up many of my images and the quality remains.
PostPosted: Fri Sep 16, 2011 3:40 am  (#9)
very nice job "O". Love the second one best, it looks like it is picking up the reflections around it.
Very nice tute Nixnine...I will try it later today.
PostPosted: Fri Sep 16, 2011 5:30 am  (#10)
Where did you get the g'mc plug-ing from? I like that. I would like to have a go at it
PostPosted: Fri Sep 16, 2011 5:42 am  (#11)
Lorri, it is in Tom Keil's filters, it is called Metallic look.
PostPosted: Fri Sep 16, 2011 6:01 am  (#12)
Oh i see do you where i can get it please I think when look lokes that it looks a lot better
PostPosted: Fri Sep 16, 2011 6:06 am  (#13)
What version do you have of G"MIC? Do you have Tom Keil's plug-ins? When you open GMIC, look at the top and it will tell you what version you have.
PostPosted: Fri Sep 16, 2011 6:14 am  (#14)
I haven't got G'MIC any version of it also don't have Tom Kelly's plug-ins either
PostPosted: Fri Sep 16, 2011 6:25 am  (#15)
You have to have GMIC to use those filters. You will have to download and install it. Here is a link. Make sure you download latest version for Windows.
G'MIC
I would download this one. gmic_gimp_1.5.0.2_win32.exe
PostPosted: Fri Sep 16, 2011 6:53 am  (#16)
Thank you Molly now installed
PostPosted: Fri Sep 16, 2011 7:10 am  (#17)
Do you have Tom Keil's name on the list? That is where the metal plug-in is.
PostPosted: Fri Sep 16, 2011 7:16 am  (#18)
no i don't had a look at it
PostPosted: Fri Sep 16, 2011 7:43 am  (#19)
Open your GMIC click about > Add Additional filters > Add Tom Keil's Filter set. After that is done, click refresh. Those are the two little curved arrows. You should now have the metal plug-ins. Also make you you have the box checked beside the internet.
PostPosted: Fri Sep 16, 2011 7:55 am  (#20)
Arr got it thanks Molly now I can do some with that siggy of mine thanks again
