It is currently Tue Nov 10, 2026 8:20 am
 Post subject: VIDEO - Adding a path via Edit/Preferences/Folders
PostPosted: Tue Sep 20, 2011 1:07 pm  (#1)
A YouTube video explaining how to add a brushes folder.All other folders are basically the same. (no audio sorry)
It's a little long waiting for gimp to load the second time i apologize for that.I had some other software running.
 Post subject: Re: Adding a path via Edit/Preferences/Folders
PostPosted: Wed Sep 21, 2011 5:29 pm  (#2)
You did the video ?
Cool, from the topic title i didn't think was a video !!
PostPosted: Wed Sep 21, 2011 5:30 pm  (#3)
COOL !!
Already used Here viewtopic.php?f=7&t=2606&p=34052#p34052
now if you accept a suggestion add "VIDEO" ,in capital letters in front of the title as
VIDEO Adding a path via Edit/Preferences/Folders and PIN it so will remain easy to find
 Post subject: Re: VIDEO - Adding a path via Edit/Preferences/Folders
PostPosted: Thu Sep 22, 2011 12:43 am  (#4)
Done, thanks PC. :)
