It is currently Tue Nov 10, 2026 8:18 am
 Post subject: Easy way to make a custom gradient in GIMP with a Palette
PostPosted: Thu Dec 22, 2011 10:34 am  (#1)
 Post subject: Re: Easy way to make a custom gradient in GIMP
PostPosted: Thu Dec 22, 2011 10:42 am  (#2)
Wow; good to see you post again Jolie. Seasons Greetings and Merry Christmas to you. :)
PostPosted: Thu Dec 22, 2011 10:44 am  (#3)
I thought it was her too Lyle but i think it is just an old tutorial moved here?
 Post subject: Re: Easy way to make a custom gradient in GIMP with a Palette
PostPosted: Thu Dec 22, 2011 10:45 am  (#4)
Oh, Lyle, Rod is correct. I copied Jolie's tutorial from Gimp Tricks. I had gotten permission from her a very long time ago to copy any of her tutorials to Gimp Chat.
PostPosted: Thu Dec 22, 2011 10:47 am  (#5)
Good to hear her voice again though. :)
PostPosted: Thu Dec 22, 2011 11:05 am  (#6)
Good to know, I just learned the other day about making a new palette from any image and then using it to pick your foreground/background colors
PostPosted: Thu Dec 22, 2011 11:07 am  (#7)
She mentions my tip for making a gradient with a palette and I hadn't posted it in Gimp Chat.
Here's the tip I had written and put over in Gimp Talk.
Making a new gradient with several colors takes awhile to make when you have several colors to add to the endpoints in the Gradient Editor.
A quicker way to do it is in the Palettes Editor:
GIMP 2.4x: <Toolbox> File > Dialogs > Palettes
GIMP 2.6x: Windows > Dockable Dialogs > Palettes
In the Palettes dialog, click the New Palette icon at the bottom - sheet of paper with a gold star - that brings up the Palette Editor.
In the Palette Editor give your palette a name. Then enter colors. Make the FG color the color you want in the palette and click the icon at the bottom to add the color to the palette (Ctrl + Click will enter the BG color). Keep doing that for each color you want in your eventual gradient.
When you have finished putting in the colors, close the Palette Editor. In the Palettes dialog right-click the palette you made and click Palette to Gradient. Your palette is now a gradient with the same name.
If you don't want to keep the palette you made, select it and click the trashcan at the bottom. The palettes that come with GIMP can't be edited but you can click Duplicate and make a new palette from one of them.
