It is currently Tue Nov 10, 2026 8:01 am
 Post subject: Color selection with G'MIC or channels
PostPosted: Tue Jun 18, 2013 5:56 am  (#1)
Here is a short video howto about the colorkey / highlight color.
Hope you like it!
BTW: Here is my Youtube channel: https://www.youtube.com/user/chrisdesignvideo
Some more videos about GIMP and Inkscape are online!
I will record many more in the next time!
 Post subject: Re: Color selection with GMIC or channels
PostPosted: Tue Jun 18, 2013 6:02 am  (#2)
Very nice Chris.F. Thanks for sharing.
PostPosted: Tue Jun 18, 2013 6:27 am  (#3)
Excellent!
Thx for the tutorial, very instructive! :bigthup
bbbbbbbbbbbImage
PostPosted: Tue Jun 18, 2013 7:13 am  (#4)
nice one Chris !
so this is basically rendering without a handmade (path, lasso, etc.) selection, right ?
does it only work with objects that are more or less one colour ?
PostPosted: Tue Jun 18, 2013 7:20 am  (#5)
Very cool Chris
PostPosted: Tue Jun 18, 2013 8:09 am  (#6)
Glad you like it! :yes
Esper: yes, this technique is the best for just one color.
But i wanted to know how to add more colors. I found out that more color layers works!
For example: this flower has reds and yellow. I need three layers of cmyk channels.
Second screenshot is made using GMIC-mask creator RGB
cron
