It is currently Tue Nov 10, 2026 8:01 am
 Post subject: MyPaint Brush Demonstrations - Video 1:
PostPosted: Mon Jul 22, 2013 7:48 pm  (#1)
Click Here For Video Link
A while back I wrote a semi review and a heavy overview of the art program MyPaint.
Although the overview was quiet detailed I thought I'd make a video and probably the first of a series based off of the brushes on MyPaint. Each brush I use, I use only that tool, not even an eraser if I wanted to erase I used white instead of the eraser. - I didn't sick with total default settings of the brush itself but it's good to see the brush used in different ways anyway.
The brushes I used are as follows:
Light Pencil
Hard Pencil
Art Pen
Inking Pen
and Fill – Marker
My Review/Overview for MyPaint can be found here.
Each section will be a mini Speed-Paint (Time-Lapse-Video), the finished drawing will show the icon for the brush I used and before beginning a drawing there will be a circles around the brush as seen in the menu. - All brushes in this video are from the “Set #2” in the brush menu. - Note: The Drawings will not be particularly awesome, it's just to get the point across.
Note: The Text Above is the same as the text in the blog post before the video.
I hope this is helpful for somebody! :D
~ God Bless ~
~ Moko
