It is currently Tue Nov 10, 2026 8:30 am
 Post subject: Lets talk stripes
PostPosted: Fri Dec 17, 2010 9:52 am  (#1)
I know I have seen it here, but can't find it..I'm wanting to make my own stripes...but don't know how...anyone point me in the right direction?
please and thank you
Micki
 Post subject: Re: Lets talk stripes
PostPosted: Fri Dec 17, 2010 10:11 am  (#2)
You might have seen it in this tutorial about how to make candy stripes. When you get down to around #15 it shows how do make them.
stripes
This is the thread the tutorial is on.
stripe thread
PostPosted: Fri Dec 17, 2010 11:18 am  (#3)
http://www.youtube.com/watch?v=dUJtrcY1he8
I saw this one quite a while back but this kid is good, it might be of use to you.
PostPosted: Fri Dec 17, 2010 12:49 pm  (#4)
If you select the "FG to BG (Hard-edged)" gradient and set the Repeat option in the Blend Tool's options dialog, you can draw stripes directly on the canvas. The direction of the stripes is perpendicular to your painting stroke and the thickness is determined by the length of your drawing stroke.
http://flashingtwelve.brickfilms.com/Players/Stripes/
PostPosted: Fri Dec 17, 2010 1:07 pm  (#5)
That is so much easier than other methods, thanks for sharing Saulgoode. =)
PostPosted: Fri Dec 17, 2010 5:58 pm  (#6)
That video was amazing.
PostPosted: Fri Dec 17, 2010 6:13 pm  (#7)
Wow, Saul, that is as good as it gets... thanx.....
