It is currently Wed Nov 11, 2026 8:13 am
 Post subject: Find Center of Canvas in Gimp (Video Tutorial)
PostPosted: Sun Dec 08, 2013 12:14 am  (#1)
Note: This script functions within Gimp Version 2.8,
however it has not been tested in Gimp 2.10.
Gregs Crosshairs.scm [1.11 KiB]
Downloaded 608 times
The Python Plug-in below,
was translated for the script and Provided By
Gimp Chat Member trandoductin.
crosshair_guides.zip [942 Bytes]
Downloaded 576 times
Once the script is installed.
It should appear at:
Image> View> Crosshair.
 Post subject: Re: Video Tutorial Uploads?
PostPosted: Sun Dec 08, 2013 1:15 am  (#2)
It works at YouTube fine, if you mean how to embed here at GC I did that on your post.
PostPosted: Sun Dec 08, 2013 8:01 am  (#3)
Wallace, there's a script to put vertical and horizontal guides at 50% of the image, named "Crosshair guides". It's very useful.
http://registry.gimp.org/node/24678
PostPosted: Sun Dec 08, 2013 8:04 am  (#4)
Or, you can go to image guides > guides by percent. Just use the dropdown arrow for horizontal and vertical.
PostPosted: Sun Dec 08, 2013 10:31 am  (#5)
Perfect way to show how to do it Molly, no video needed
PostPosted: Sun Dec 08, 2013 11:35 am  (#6)
If you just need to find an exact center, two diagonal lines from the corners on transparent layer will do the job.
Snap to grid feature is easy to overlook. Besides, unlike actual guides you can turn off the visibility of a 'guide' layer.
As for the predefined guides script, GAT is the most versatile, imo - http://registry.gimp.org/node/25332
PostPosted: Sun Dec 08, 2013 12:56 pm  (#7)
Okay, yes that is what I wanted to do. Thanks Odin. :bigthup
PostPosted: Sun Dec 08, 2013 12:58 pm  (#8)
Didn't know there was a script, thanks Carlos Diniz.
PostPosted: Sun Dec 08, 2013 1:00 pm  (#9)
Yes Molly, this is what my video is trying to demonstrate. It's a very simple/basic tutorial, just thought I'd through it out there. :mrgreen:
PostPosted: Sun Dec 08, 2013 1:05 pm  (#10)
This looks like a very useful plugin, thanks K1TesseraEna.
PostPosted: Sun Dec 08, 2013 4:27 pm  (#11)
GAT tools is good but I keep forgetting about it being in the tools menu. I don't know if it was mentioned, Grid of guides is a good one to have as well.
PostPosted: Sun Dec 08, 2013 4:35 pm  (#12)
Yes good suggestions, thanks Odin. ;)
 Post subject: Re: Find Center of Canvas in Gimp (Video Tutorial)
PostPosted: Sun Dec 08, 2013 4:45 pm  (#13)
this article introduces best guide scripts available for gimp (with links)
PostPosted: Sun Dec 08, 2013 5:05 pm  (#14)
This allows you to choose either the active layer or the canvas to split.
http://www.gimpchat.com/viewtopic.php?f=9&t=4657#p57940
PostPosted: Mon Dec 09, 2013 6:34 am  (#15)
Sorcery!
This is me eyeballin' rule of thirds -.-
PostPosted: Sun Apr 07, 2019 1:23 pm  (#16)
A script and plug-in.
Has been added to the main/first post of this thread.
Follow the Gimp Chat link below,
to acquire the script or plug-in.
viewtopic.php?f=24&t=9207&p=119241#p119241
