It is currently Wed Sep 30, 2026 8:23 am
 Post subject: Help
PostPosted: Wed May 07, 2014 9:36 pm  (#1)
twirl.xcf
I have done this over a time. Uploaded the gif and am not sure why it loaded as a still so I will just attach the xcf now.
What I need help with is - the quadrilaterals only appear one line at a time. 1st side, 2nd then 3rd and lastly 4th until the whole shape is there, then the next and then the next.
I also need this to after the whole is there to shrink and grow. Shrink towards the centre and grow larger every time. 3-4 times.
Be great if someone can do it for me.
 Post subject: Re: Help
PostPosted: Wed May 07, 2014 10:29 pm  (#2)
it looks to me like you simply have to make a little larger backgorund
when you rotate an object it uses a little larger screen background
than the drawing actually is, by using the drawing padding.
thiis the simple explanation. maybe this will help.
PostPosted: Wed May 07, 2014 10:50 pm  (#3)
spellingImage
i guess my fingers don't as well as they once did sorry for the spelling
and if this shows up two times i guess it is the fingers again sorry
