It is currently Wed Sep 30, 2026 11:16 am
Post new topic Reply to topic  [ 57 posts ]  Go to page 1, 2, 3  Next
 Post subject: Font with Lightning Bolt Tutorial
PostPosted: Thu Aug 14, 2014 10:52 pm  (#1)
I searched and found a script and a video tutorial on this topic.
Script - Lightning Bolt
Video tutorial - A Gimp Animated Lightning Text Effect
bbbbbbbbbbbImage
 Post subject: Re: Font with Lightning Bolt Tutorial
PostPosted: Fri Aug 15, 2014 6:00 am  (#2)
Very good find Akros. Who is the funny guy who loves purple with the nice voice?
Nice tutorial Wallace
PostPosted: Fri Aug 15, 2014 6:08 am  (#3)
I know who that is. ;)
It's unfortunate, but this script, Lightning Bolt. That creates an animated lightning bolt; doesn't work with Gimp 2.8.
PostPosted: Fri Aug 15, 2014 6:16 am  (#4)
Thought I recognized the face. lol
Nice tut; too bad there's incompatibilities with the tools used for 2.8. :)
PostPosted: Fri Aug 15, 2014 6:18 am  (#5)
Thats too bad Wallace, I was looking forward to doing that tute, I even downloaded the script. Let us know if you want to leave this thread in or remove it. (pm sent)
EDIT:
I just tried the script Wallace and it worked for me on gimp-2.8.10 . Haven't tried the tute yet though.
PostPosted: Fri Aug 15, 2014 6:41 am  (#6)
The script has also worked for me Wallace.
PostPosted: Fri Aug 15, 2014 6:45 am  (#7)
There was a line in the script that needed to be changed. I did this and it now works with my Gimp 2.8.
will-lightning.scm [5.18 KiB]
Downloaded 415 times
PostPosted: Fri Aug 15, 2014 6:54 am  (#8)
EDIT:
I'm not sure if that tutorial can be followed as it is. In the tutorial I used the "Combine" scripts that came with the Gimp GAP package. This GAP package, to my knowledge, is no longer available for Gimp 2.8.
Can the combine scripts be found elsewhere? That would be the "Combine Background" and "Overlay Background" scripts.
Edit...
I'm mistaken, these scripts can be found in the "FX-Foundry" under "Animation", if you have this installed.
PostPosted: Fri Aug 15, 2014 7:03 am  (#9)
Combine background and Overlay background come together as a package by saulgoode.
http://gimpscripts.com/?s=combine+background
PostPosted: Fri Aug 15, 2014 7:07 am  (#10)
I wasn't aware of this, but I have them in FX-Foundry. Could these be the scripts by saulgoode? The ones I used for my tut were provided by the GAP package.
PostPosted: Fri Aug 15, 2014 7:09 am  (#11)
If you right click on the script and open in an editor, it should say who it is by. I don't think Sauls are under FX-foundry
In your gimp the two Saul scripts will be found under Filters > Animations
PostPosted: Fri Aug 15, 2014 7:20 am  (#12)
In your gimp the will be found under Filters > Animations
Thanks Molly for the link, now I have this under Filters > Animation as well as the FX-Foundry menu.
You are welcome, I dumped FX-Foundry and everything in it 3 years ago. Too many old scripts in there that have never been updated.
PostPosted: Fri Aug 15, 2014 7:23 am  (#13)
Thanks Wallace, I cant find my version, but it had a different result.
This looks pretty good though :bigthup
PostPosted: Fri Aug 15, 2014 7:46 am  (#14)
Thanks Wallace,
I dumped my FX-Foundry 3 years ago and everything in it. I found that there are too many old scripts there that need updating.
PostPosted: Fri Aug 15, 2014 7:51 am  (#15)
No problem. ;)
The old script is named, "sf-will-lightning.scm". I just remover the "sf-" for the file name and changed the line that needed to be changed in the old script.
I found this information at the Gimp Plugin Registry in the comments pertaining to this script.
That's funny, because I just added it to my Gimp. :hehe
PostPosted: Fri Aug 15, 2014 9:11 am  (#16)
PostPosted: Fri Aug 15, 2014 9:18 am  (#17)
:hehe
PostPosted: Fri Aug 15, 2014 11:31 am  (#18)
Hey Molly, he looks familiar, I think he must be a famous artist. I'm trying to remember in which movie I should have seen him. ;)
Did you see the effect that text "illuminances"? :bump
Came out pretty well ... would he do a tutorial about this effect? :roll:
With more time I'll try to play the tutorial;
Wallace Thx! Very well explained! :tyspin
bbbbbbbbbbbImage
PostPosted: Fri Aug 15, 2014 11:35 am  (#19)
Yes his work is great and flawless, don't tell him I said so.
PostPosted: Fri Aug 15, 2014 1:31 pm  (#20)
I thought I'd post this before I left the house on a trip to the store. I had to retrieve the XFC file for my old computer and add the lightning bolt once again using my 2.8. Gimp. ;)
