It is currently Thu Oct 08, 2026 6:43 pm
 Post subject: Using 'my' paint with guidelab (orignal Arkane, changed)
PostPosted: Thu Nov 10, 2016 3:31 am  (#1)
Hi,
The plugin with .. in the zip file (explanation in German in paint_with_guides.txt)
From 11.11 11:11
guidelab_paint.zip [780.19 KiB]
Downloaded 203 times
here the UI for my adjusted guidelab:
and here an example of use to build a GIF
 Post subject: Re: Using 'my' paint with guidelab (orignal Arkane, changed)
PostPosted: Thu Nov 10, 2016 7:11 am  (#2)
PKHG wrote:
Hi,
Pretty cool! :)
PostPosted: Thu Nov 10, 2016 7:21 am  (#3)
[quote="Rod"]
Thanks ;)
Now an example WITH the use of the Simple path plugin used:
or this :yes
PostPosted: Fri Nov 11, 2016 6:07 am  (#4)
zip file with plugin see first post of this thread ;)
PostPosted: Fri Nov 11, 2016 6:35 am  (#5)
Are the PDB calls still the same with MareroQ's newest version 1.1?
PostPosted: Fri Nov 11, 2016 9:03 am  (#6)
no not yet ... will work on it soon ...
PostPosted: Fri Nov 11, 2016 12:50 pm  (#7)
Hi Peter.
I really like Your idea.
Unfortunately for me it's still not working properly (maybe my mistake?).
Creates a selected path at the intersection of the guides - other options in section "Simple Path" does not work (and probably are not needed - possibly beyond the pattern fill).
Do you need to use it „Clipboard” (gimp-context-set-pattern) ? - because it's the translation problem.
Yours in anticipation of the next version...
PostPosted: Sat Nov 12, 2016 2:09 am  (#8)
MareroQ.
Yes the Clipboard is used at this moment for filling. I will change it soon and upload it here.
Suggestion: could you give different names, which will be used in other scripts (I mean, what will be visible asking the pdb) to your uploaded new versions of "Simple ... "?
Others: How to check in a nice easy way if a plugin is available IN a plugin?
PyGtkers: how to use a Frame in gtk, I can make it visible with a title, but adding other widgets do not show up.
Sorry, for different types of answer/questions ... but readers of this are probably of different 'type' (so to say :) ).
Peter
Works now:
At this moment the switch to select random patterns is on the Add/Edit tab, should probably got to the 4th tab too (or a message there)
Here the file:
guidelab_paint_201.zip [11.96 KiB]
Downloaded 181 times
PostPosted: Sat Nov 12, 2016 4:22 pm  (#9)
Can someone tell me where to find this plugin in the Gimp menu. I put it in the plugin folder checked its permissions and can't see it anywhere. I don't read german. :gaah
I found it. :yes For some reason I didn't think to look under Image/Guides. :roll:
PostPosted: Sun Nov 13, 2016 5:34 am  (#10)
Sorry, next version will include an English installation and info text-file . Soon,
because the Plugin has becom better with respect to the Simple path shapes ...
PostPosted: Mon Nov 14, 2016 3:25 am  (#11)
Finally found what I need, at least working in the Python Console of Gimp
#http://mailman.daa.com.au/cgi-bin/pipermail/pygtk/2003-February/004454.html
import gobject
import gtk
COLUMN_TEXT=0
# initialize the ListStore.  Fom more complicated lists, see pygtk src example
# pygtk-demo/demos/list_store.py
#ORiGinal mydata = ['John', 'Miriam', 'Rahel', 'Ava', 'Baerbel']
num_patterns, mydata = pdb.gimp_patterns_get_list('')
model = gtk.ListStore(gobject.TYPE_STRING)
for item in mydata:
    iter = model.append()
    model.set(iter, COLUMN_TEXT, item)
# set up the treeview to do multiple selection
#PKHG>INFO neline needed for Gimp Python Console
treeview = gtk.TreeView(model)
treeview.set_rules_hint(gtk.TRUE)
column = gtk.TreeViewColumn('Name', gtk.CellRendererText(),
                            text=COLUMN_TEXT)
treeview.append_column(column)
treeview.get_selection().set_mode(gtk.SELECTION_MULTIPLE)
# when you click ok, call this function for each selected item
def foreach(model, path, iter, selected):
    selected.append(model.get_value(iter, COLUMN_TEXT))
def ok_clicked(event):
    selected = []
    treeview.get_selection().selected_foreach(foreach, selected)
    print 'And the winners are...', selected
    #gtk.main_quit()
def endme_clicked(event):
    gtk.main_quit()
# the rest is just window boilerplate
win = gtk.Window()
win.connect('destroy', lambda win: gtk.main_quit())
win.set_title('GtkListStore demo')
win.set_border_width(8)
vbox = gtk.VBox(gtk.FALSE, 8)
win.add(vbox)
label = gtk.Label('Select your firends and family')
vbox.pack_start(label, gtk.FALSE, gtk.FALSE)
sw = gtk.ScrolledWindow()
sw.set_shadow_type(gtk.SHADOW_ETCHED_IN)
sw.set_policy(gtk.POLICY_NEVER,
              gtk.POLICY_AUTOMATIC)
vbox.pack_start(sw)
sw.add(treeview)
win.set_default_size(280, 250)
endme = gtk.Button("END")
endme.show()
endme.connect("clicked",endme_clicked)
vbox.pack_end(endme)  #PKHG>????
button = gtk.Button('OK')
button.show()
button.connect("clicked", ok_clicked )
vbox.pack_end(button,gtk.FALSE)
win.show_all()
gtk.main()
Now I will try to put it into my plugin, working for selecting patterns to be used ;-)
