Tas_mania wrote:
Thanks Pat625 and Steve.
Steve, I was going to use your script if the animation merge script didn't work. I'm yet to learn the difference in the scripts. It appears Wills animation merge preserves the timing of individual animations. I think the LHS animation is going faster than the one on the RHS. That was unexpected.
If Wills animation merge script is giving the results you want then that's the one to use
The difference between Wills script and mine, is Wills merges two gifs into one, mine will merge numerous gifs into one so long as the rules are followed.
I designed it so that if I was working on say a space animation scene with 20 different objects each having 15 layers, I can work on and save each object as a stand alone gif. I can then stack all, some or a combination of the stand alone gifs in gimp and run my script to shuffle and merge them into one gif. If I disliked how one of the objects looked I could easily rerun the script minus that one object.
As to preserving the timing of individual animations, my script is designed only to stack, shuffle and merge gifs, I don't think it alters any of the layer timings but I can't be sure of this, perhaps someone who is more knowledgable on how gifs work could throw some light on this
