It is currently Fri Oct 02, 2026 10:19 pm
 Post subject: Making Animated Miniplanets
PostPosted: Fri Apr 20, 2018 6:48 am  (#1)
There is a nice tutorial on making miniplanets here.
What about animated miniplanets? I used MathMap Composer and different combinations of elements. It became obvious you can make all sorts of weird little planets. I even made a square miniplanet.
a Panini miniplanet
a decorative miniplanet
These are the Composer elements used in the animations above. 'StereoNdeG' is the miniplanet element, 'rotate_time' is a handy utility by Nevitt that can rotate many MathMap elements. 'Panini' makes the hour glass shape. Adding waves to a miniplanet is just one of many possible effects.
 Post subject: Re: Making Animated Miniplanets
PostPosted: Fri Apr 20, 2018 10:31 am  (#2)
Tas_mania, thanks for sharing it. Your planets are alluring. :tyspin :coolthup
PostPosted: Fri Apr 20, 2018 4:47 pm  (#3)
Those are very clever. Like them a lot. Last one is so fluid that it reminds me of a lava lamp.
PostPosted: Fri Apr 20, 2018 8:04 pm  (#4)
Thanks Issabella for liking my miniplanets.
I'm glad you like them Pat. I try to think outside of the square.
I found a great tut on making 'little planets' that uses polar coordinates not Mathmap. here.
He shows the best way of merging the Left and Right hand sides of a graphic. I'm lazy and use mirror images but I will use his method as well.
There is almost nothing on animated miniplanets but there will be some in my next video :)
