It is currently Sat Oct 03, 2026 9:40 am
 Post subject: A stop watch in Gimp
PostPosted: Sun May 29, 2011 3:12 pm  (#1)
sport-stop-rd.xcf [588.31 KiB]
Downloaded 199 times
 Post subject: Re: A stop watch in Gimp
PostPosted: Sun May 29, 2011 4:01 pm  (#2)
very nice! Love the light grey unused number bits.
PostPosted: Sun May 29, 2011 7:17 pm  (#3)
Excellent. It looks almost like a photo.
PostPosted: Sun May 29, 2011 8:52 pm  (#4)
Very nice Rod!
I'm back I think
PostPosted: Sun May 29, 2011 9:10 pm  (#5)
Awesome result Rod! :bigthup
Would be fun to animate that.
PostPosted: Mon May 30, 2011 8:29 am  (#6)
Wouldn't be hard. :) Just add a different face plate each frame.Go for it ccbarr!
Thanks for your kind comments every one.
PostPosted: Mon May 30, 2011 10:02 am  (#7)
I changed the design to be a sort of two minute digital timer using GAP. Doing it all manually would take a lot of time, whereas GAP nicely automates much of the repetitive stuff. The other nice thing is this GIF file size is less than 100 K, which gives it a fairly nice small footprint. :)
Thanks for sharing your XCF file so that I could make this possible Rod.
:tyspin
I will have to bundle the XCF files I used for the animation and add them here as a ZIP file for anyone wanting to examine them.
PostPosted: Mon May 30, 2011 11:15 am  (#8)
Here is an update to the original, done in Gimp and GAP, with some additional animation features:
Thanks again to Rod for the original XCF permitting me to add to his work to make this and the above.
Note: I have included a ZIP file containing the XCF files I used to build the above animation. Feel free to inspect them and use them to attempt to duplicate either the first animation or the second one posted here if you wish.
two_minute_timer_files.zip [63.25 KiB]
Downloaded 165 times
PostPosted: Mon May 30, 2011 11:41 am  (#9)
Wow thats amazing ccbarr!
I'm back I think
PostPosted: Mon May 30, 2011 4:24 pm  (#10)
Very cool - both the original and ccbarr's adaption!
Griatch
PostPosted: Mon May 30, 2011 4:57 pm  (#11)
O My, ccbarr that is amazing. Love the little Wilber in there.... very nice work....
PostPosted: Mon May 30, 2011 10:58 pm  (#12)
@ Rod very cool. :) Looks real.
@ccbar neat now it even works :)
Liana
PostPosted: Tue May 31, 2011 12:45 am  (#13)
Lots of talent here! Great work!
My Sigs = My Photos
PostPosted: Tue May 31, 2011 12:48 am  (#14)
I love them both ccbarr! Especially the one with Wilbur. :)
Thank you for taking the time to animate them.You do such awesome GAP work my friend.
And thanks for the finished work space files.I'll definitely be exploring those more closely.
PostPosted: Wed Jun 01, 2011 4:49 pm  (#15)
Great job! This is amazing!
PostPosted: Fri Jun 03, 2011 4:06 pm  (#16)
Former Member
Nice stopwatch Rod! Not digging the top, and bottom fonts though. I also noticed a bit of pixelation on the top of the stopwatch. Not much, but it is noticeable.
I made a stopwatch, and called it TimeSamurai, it's a chrome extension, a web app, and a java application. (1 word boredom lol) Check it out!
PostPosted: Thu Jun 09, 2011 9:12 am  (#17)
Now that's called teamwork. Awesome work.
Portable dvd player
