It is currently Tue Nov 17, 2026 6:17 pm
 Post subject: Challenge
PostPosted: Wed Oct 26, 2022 11:26 pm  (#1)
Well, for me it would be.
Can anyone make an animation out of this picture here https://www.deviantart.com/sallyanneste ... -919657634
If you could give it a twirling look like a worm hole. I am no good at animations - is it possible?
 Post subject: Re: Challenge
PostPosted: Thu Oct 27, 2022 1:47 am  (#2)
I recommend IWARP as you can save the twirl as an animation directly through the plugin. :)
I have placed the IWARP plugin from portable 2.8 in my plugins folder for Gimp-2.10.32 and it works fine. :bigthup
I can upload IWARP here if you want. :)
PostPosted: Thu Oct 27, 2022 2:04 am  (#3)
This is just rotating the layers by increments of different amounts.(a gif)
PostPosted: Thu Oct 27, 2022 2:08 am  (#4)
wow, that's cool Rod (snap) your first post ;). I never even thought it could be but I showed the pic to a friend and he suggested it.
Yes please post the iwarp
PostPosted: Thu Oct 27, 2022 2:14 am  (#5)
No problem , here you go. ;) :bigthup
iwarp.7z [25.17 KiB]
Downloaded 180 times
I placed mine inside a folder named iwarp and then i placed that folder inside the plugins folder. Then restart Gimp.
It will be under Filters>Distorts>Iwarp.
Have fun! :hehe
PostPosted: Thu Oct 27, 2022 2:20 am  (#6)
PostPosted: Thu Oct 27, 2022 3:27 am  (#7)
i had a go at it. Might try again though
PostPosted: Thu Oct 27, 2022 4:52 pm  (#8)
A Fab image Sally, very striking
My try using a couple of home made scripts
PostPosted: Fri Oct 28, 2022 3:12 am  (#9)
Thank you Steve, very good :)
PostPosted: Fri Oct 28, 2022 2:40 pm  (#10)
Hello, :)
Beautiful image :coolthup
Playing with the scale, rotation and stacking :
PostPosted: Sat Oct 29, 2022 9:07 pm  (#11)
WOW! Brilliance from every one. Love it.
PostPosted: Sun Oct 30, 2022 3:12 am  (#12)
nice Jimmy :)
Thank you all for your contributions
PostPosted: Sun Oct 30, 2022 2:12 pm  (#13)
There is a lot to play just with the Warp tool, many options ;)
don't forget to click "Create Animation" once you're happy with the END result, GIMP will create an animation from the start you use the warp transform tool up to the end result
Patrice
PostPosted: Sun Oct 30, 2022 5:46 pm  (#14)
Very cool PixLab - you are way in front of the crowd :jumpclap
I like the way it's saved as 'webp' that is just for browsers. Also Gimp Chat obediently uploads it even though it is bigger than the upload limit.
Cheers from raining Tasmania :)
PostPosted: Mon Oct 31, 2022 8:15 pm  (#15)
Thank you Tas_mania.
Patrice
