It is currently Fri Nov 13, 2026 3:41 pm
 Post subject: frame issue?
PostPosted: Fri Nov 08, 2024 12:31 pm  (#1)
hello i'm new to the forum. i made an emoji ringing bells but as the bell is being rung you see the previous bell. at the end you see every bell frame.
 Post subject: Re: frame issue?
PostPosted: Fri Nov 08, 2024 1:41 pm  (#2)
when you save animated gif there's option to replace every frame instead of combined.
PostPosted: Fri Nov 08, 2024 1:44 pm  (#3)
No need to post twice .... @Dark-Anna
PostPosted: Fri Nov 08, 2024 2:31 pm  (#4)
sorry i didn't mean to post it twice.
PostPosted: Sat Nov 09, 2024 12:45 am  (#5)
Hi Dark-Anna,
Mostly you do replace frames except the bottom layer which is 'combine' and then delete. It was going thru a cycle with the right arm and then the left so I merged frames.
2 and 8
3 and 9
4 and 10
5 and 11
6 and 12
7 and 13
after deleting the bottom layer it leaves 6 frames,
