It is currently Sat Oct 03, 2026 12:16 pm
 Post subject: Cylinder With Sliding Door
PostPosted: Sun Oct 30, 2011 3:09 pm  (#1)
Made with Gimp and GAP, primarily using Frames Modify with Map Object. It's just a basic concept at the moment. In it's completed state, it would have some mechanism attached and moving the doors along with maybe something interesting going on inside the cylinder when the doors open.
Thank you for checking it out.
 Post subject: Re: Cylinder With Sliding Door
PostPosted: Sun Oct 30, 2011 3:10 pm  (#2)
That's pretty awesome! You're a GIMP wizard.
PostPosted: Sun Oct 30, 2011 3:12 pm  (#3)
Amanda47,
Thank you for the kind words. Glad you enjoyed it.
PostPosted: Sun Oct 30, 2011 3:27 pm  (#4)
I second that one Amanda. awesome.
PostPosted: Sun Oct 30, 2011 4:08 pm  (#5)
molly,
Thank you very much.
PostPosted: Sun Oct 30, 2011 4:39 pm  (#6)
That's groovy, man.
PostPosted: Sun Oct 30, 2011 4:44 pm  (#7)
nixnine,
Thank you.
PostPosted: Mon Oct 31, 2011 9:07 am  (#8)
Sweet! Thanks.
PostPosted: Mon Oct 31, 2011 12:23 pm  (#9)
That is some animation there
PostPosted: Mon Oct 31, 2011 11:30 pm  (#10)
You own GAP!!
PostPosted: Tue Nov 01, 2011 6:14 am  (#11)
Wow....that's fascinating,Ccbarr :bigthup :)
My Flickr
