It is currently Sat Oct 03, 2026 3:39 am
 Post subject: GAP Video Text Effect
PostPosted: Sat Jun 09, 2012 7:46 pm  (#1)
It's a bit difficult to see the 3D rotation of this text since the image size is on the small side. If this were for an actual video, I probably would have used 1280x720 for the image size.
Again, this is a video title sequence effect that I have seen used on youtube videos. It took some time to figure this one out. In fact, it's still a work in progress.
Thank you for checking out this animation.
 Post subject: Re: GAP Video Text Effect
PostPosted: Sat Jun 09, 2012 7:49 pm  (#2)
I'd love to know how you do that. Does it involve Map Object again?
PostPosted: Sun Jun 10, 2012 5:06 am  (#3)
That is beautiful ccbarr.
PostPosted: Thu Jun 14, 2012 10:12 am  (#4)
molly: Thank you for your comment.
Erisian:
It was a combination of Move Path, to set the basic horizontal movement of the text. The changing speed of the moving text involved using the Keyframe setting in Move Path. Then it was Frames Modify using Apply Filter on Layer(s) to give a Horizontal-only Gaussian Blur to the moving text. Multiple layers were then combined using Frames Modify. I needed to get a consistent sized layer for the final step, so I had to add a transparent frame using Move Path and merge it with the first two text phrase layers and then later with the last two text phrase layers. Finally Frames Modify with Apply Filter on Layer(s) using Map Object was used to give the spinning effect to the text.
Thank you for your interest in the animation.
PostPosted: Thu Jun 14, 2012 10:14 am  (#5)
Thank you ccbarr. :)
