It is currently Sat Oct 03, 2026 12:18 pm
 Post subject: Animation layer attributes? [SOLVED]
PostPosted: Wed Aug 22, 2012 12:54 am  (#1)
I have an animation with over 100 cells. I need to change the layers attributes from "combine" to "replace".
Is there a way that I can change this, without having to change each layers attribute manually from combine to replace? :(
Isn't there a script that will change all the layers attributes instead of me doing this all manually for each layer? :gaah
 Post subject: Re: Animation layer attributes?
PostPosted: Wed Aug 22, 2012 1:17 am  (#2)
http://chiselapp.com/user/saulgoode/rep ... m-settings
PostPosted: Wed Aug 22, 2012 1:25 am  (#3)
saulgoode wrote:
http://chiselapp.com/user/saulgoode/repository/script-fu/wiki?name=sg-anim-settings
Hey! thanks saulgoode... I think this will do the trick and this post was only up for a few minutes. :yes
