It is currently Sun Oct 04, 2026 3:53 pm
 Post subject: how is this done?? please help...
PostPosted: Fri Aug 24, 2012 11:50 pm  (#1)
i am not new to gimp. but i am new to gimp animations. i am using gimp 2.6 on windows 7..and here is my question, i just made a small animation, about 14 frames, and i saved it..so how do i get it to play outside of gimp. in other words can it only play in gimp? i have windows live movie maker and i loaded it up into it and it will not play....how do i get this to work...please help...thanks
 Post subject: Re: how is this done?? please help...
PostPosted: Sat Aug 25, 2012 12:08 am  (#2)
You need to save it as either a APNG or GIF file.Most likely you do not have apng installed so use GIF. :)
Then select save as animation in the dialog that opens.
PostPosted: Sat Aug 25, 2012 1:36 am  (#3)
well i did this and it still will not play outside of gimp...
PostPosted: Sat Aug 25, 2012 1:54 am  (#4)
Internet Explorer 9 can play them on Windows 7.
PostPosted: Sat Aug 25, 2012 2:05 am  (#5)
When you say you did this, what did you do?
Did you export as gif or png?
Did you check the animation option in the export dialog?
PostPosted: Sat Aug 25, 2012 10:09 am  (#6)
Download Virtual Dub, open your Gif in VD and save it as an avi.
http://virtualdub.sourceforge.net/
PostPosted: Sat Aug 25, 2012 10:16 am  (#7)
as default export as gif will FLATTEN :gaah
So it would destroy the animation...very dumb default since nowadays there are no reasons to save as gif something that is not a animation...but alas that the default
so i imagine you just used the default without noticing the "save as animation " box
PostPosted: Sat Aug 25, 2012 1:50 pm  (#8)
xnview will also play them as animations.
PostPosted: Tue Aug 28, 2012 4:53 am  (#9)
lol..i think i figured it out.....i know its not much but i just wanted to see if it would play...lol... :yes :yes :yes :yes
PostPosted: Tue Aug 28, 2012 9:02 am  (#10)
:clap :jumpclap :hi5 :yes
