It is currently Tue Oct 06, 2026 5:23 am
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2, 3  Next
 Post subject: Reverse Trompe-l'oeil
PostPosted: Sat Sep 01, 2012 8:07 am  (#1)
Hi there,
I was playing today with some scripts to create animated GIF, and had an idea, which could be considered as a 'Reverse Trompe-l'oeil' effect :p
According to Wikipedia, a Trompe-l'oeil is a 2d picture that creates the optical illusion of having 3d objects in front of the viewer.
Here, I propose to do exactly the opposite, which is creating a 3d object that creates the optical illusion of having a simple 2d shape, when rendered on an image (and of course, the 2d shape is not present as it, in the 3d object).
For this purpose, I've created another G'MIC script that create a random-looking 3d object, but when it is rendered at two specific view angles, the viewer has the impression to see regular 2d texts (here, I used 'GIMP' and 'Chat' of course :jumpclap ).
Once the object is created, I just have to map some random texture on it, and create a 3d motion that interpolates between these 2 particular angles.
Here is the result :
Hope you'll like it. Personally, I do ! As you can see, I'm not an artist, I only know how to code graphical stuffs. But even in this case, we can have some inspiration sometimes :)
 Post subject: Re: Reverse Trompe-l'oeil
PostPosted: Sat Sep 01, 2012 8:14 am  (#2)
That is so very cool. I like it too.
PostPosted: Sat Sep 01, 2012 8:16 am  (#3)
I really like that one. Nice work.
:ninja - Thanx Mo.
PostPosted: Sat Sep 01, 2012 8:21 am  (#4)
The cool thing with being a programmer, is that you can only change a parameter an get a new rendering easily, without spending hours in pixels manipulation :p
Thanks molly !
PostPosted: Sat Sep 01, 2012 10:36 am  (#5)
This is a very nice feature :jumpclap :tyspin
PostPosted: Sat Sep 01, 2012 10:38 am  (#6)
Thanks molly !
Wow that is so cool David. Thanks :yes
PostPosted: Sat Sep 01, 2012 10:41 am  (#7)
Thanks molly !
You're a genius David. Can you do the impossible as well? :)
PostPosted: Sat Sep 01, 2012 12:01 pm  (#8)
its magic ! :mrgreen:
PostPosted: Sat Sep 01, 2012 12:08 pm  (#9)
@Erisian : Of course I can ! ;)
PostPosted: Sat Sep 01, 2012 1:04 pm  (#10)
And here is variation of the famous Yes/No sculpture
Here is mine (more complicated to make for real, unfortunately :p)
PostPosted: Sat Sep 01, 2012 1:20 pm  (#11)
That's a way cool effect, Ronounours.
Also, I really like your new avatar. :yes
PostPosted: Sat Sep 01, 2012 7:23 pm  (#12)
That is super cool!
PostPosted: Sat Sep 01, 2012 7:31 pm  (#13)
Another winner, David :bigthup
The scripts keep coming. I'm out of breath trying to keep up with you!
PostPosted: Sat Sep 01, 2012 8:02 pm  (#14)
Where is it in G'MIC?
PostPosted: Sat Sep 01, 2012 8:04 pm  (#15)
:gaah
is the script supposed to be saved as a text?
When i saved it,all I get is this:
gimpchat : -skip ${1=32}
-if gimpchat.cimgz
gimpchat.cimgz
-else
# Generate 3d object.
0 -text GIMP,0,0,57,1,255
0 -text[-1] Chat,0,0,57,1,255 -mirror[-1] y
-expand_xy 10,0
-dilate 3
-elevate 64
-permute[-1] zyxc
-r @{-max_whd}
-and
100%,100%,100% -noise[-1] 1 -b[-1] 7 -otsu[-1] 256 -*[-2,-1]
-b 1 -isosurface3d 25%
-f3d 4000 -db3d 0 -m3d 5
# Generate light texture.
256,256,1,3 -plasma[-1] 1,1 -equalize[-1] 256 -n[-1] 0,255
--gaussian[-1] 40%,40%,0 -n[-1] 0,1 -*[-2,-1]
--gaussian[-1] 10%,10%,0 -n[-1] 0,200 -+[-2,-1]
-c[-1] 0,255
-l3d [-1] -rm[-1]
-c3d -n3d -*3d[-1] 250
# Render animation.
-repeat $1
angle={$>*360/$1}
--r3d[0] 1,0,1,$angle
400,400,1,3,-1
-object3d[-1] [-2],50%,50%,0,1 -rm[-2]
-w[-1]
-done
-rm[0]
-a z -autocrop -1 -s z
-to_rgba -replace_color 0,0,-1,-1,-1,255,0,0,0,0
-o gimpchat.cimgz
-endif
-repeat @# -l[$>]
--channels 3 -negative[-1] -b[-1] 2 -shift[-1] 5,5,0,0,1
-rv -compose_alpha
-endl -done
-i[{$1/2}] [{$1/2}]x19
-i[0] [0]x19
so now what do i do with it? :)
help
PostPosted: Sat Sep 01, 2012 8:43 pm  (#16)
Fantastic!
I did not know that technique.
PostPosted: Sun Sep 02, 2012 1:41 am  (#17)
That is one of the neatest scripts you have written yet David. :)
PostPosted: Sun Sep 02, 2012 2:59 am  (#18)
Note that I wrote this script for a personal use, and didn't put it in the G'MIC plug-in.
But if you are interested, of course, I can rework on it a little bit and put it in the 'Sequences/' folder in the plug-in.
PostPosted: Sun Sep 02, 2012 3:32 am  (#19)
Thats an amazing effect.
PostPosted: Sun Sep 02, 2012 4:19 am  (#20)
pirate541 wrote:
:gaah
-if gimpchat.cimgz
gimpchat.cimgz
-else
-expand_xy 10,0
-dilate 3
-elevate 64
-permute[-1] zyxc
-r @{-max_whd}
-and
-c[-1] 0,255
-l3d [-1] -rm[-1]
# Render animation.
-repeat $1
angle={$>*360/$1}
400,400,1,3,-1
-w[-1]
-done
-rm[0]
-o gimpchat.cimgz
-endif
-repeat @# -l[$>]
-rv -compose_alpha
-endl -done
-i[0] [0]x19
help
Pirate, when you save a script you put a .scm extension not .txt.
