It is currently Sat Aug 08, 2026 2:03 pm
 Post subject: One turned into many
PostPosted: Sat Dec 29, 2012 11:32 pm  (#1)
Not sure exactly how I done this. I did turn the goblet around a few times so all I can think of is I made a new layer each time?
 Post subject: Re: One turned into many
PostPosted: Sun Dec 30, 2012 8:13 am  (#2)
I'm not sure what you were trying to accomplish, sallyanne, but what you got was really a messed up animation.
I played with your image to make it smoother. These are the results.
Get the Animation Settings and Combine background/Overlay background scripts by saulgoode. They are practically essential for making animations. Settings sets the timing and replace/combine modes, the Combine background one does just that. Create a background for your animation and it puts it on each image.
They are listed under Animations on this website: http://chiselapp.com/user/saulgoode/rep ... pt-fu/home
PostPosted: Sun Dec 30, 2012 10:25 am  (#3)
:tyspin Thanks Oregonian. What you have done looks much better.
I wasn't trying to make an animation. I was only playing around. I didn't intentionally make extra layers either. Can they be added automatically?
