It is currently Wed Sep 30, 2026 8:23 am
 Post subject: Animation Puzzle Challenge.
PostPosted: Mon Feb 25, 2013 11:06 pm  (#1)
i sometimes like making animations with gimp. i thought of something that i think would take time to make. so i thought this would make a good thread and challenge others to see how they would pull this off. here is my idea: to take a photo(any photo) and turn it into a puzzle using gimp. once you have made the puzzle make a animation showing the puzzle being put together in front of your eyes. how many pieces you use to make your puzzle is up to you, but i don't think a puzzle with ten pieces would be all that hard. i have started on mine already. and i think i have 27 pieces in mine. but that may change. anyways i think this may be fun to see others animations on this one. so i hope you will do one. it may be harder then you think. i hope others will give it a try. thanks for viewing my thread and good luck on your puzzle :) :)
 Post subject: Re: Animation Puzzle Challenge.
PostPosted: Mon Feb 25, 2013 11:42 pm  (#2)
This is definitely an interesting Idea and I'm sure if you get a good result we would all love a tutorial on how it was achieved
PostPosted: Tue Feb 26, 2013 12:04 am  (#3)
i am working on it. but i work 40 hours a week so it may take a while. :)
PostPosted: Tue Feb 26, 2013 12:30 am  (#4)
Using the right steps it does not take long
PostPosted: Tue Feb 26, 2013 1:02 am  (#5)
thats nice but i was gonna show all the pieces in each frame. so it looks like a puzzle took a part and then being put together. but nice job.
PostPosted: Tue Feb 26, 2013 2:47 am  (#6)
Rdgracer71 I also cheated by writing a quick script to do mine I'm not sure what you mean so I'll have to wait to see what you come up with
PostPosted: Tue Feb 26, 2013 3:24 am  (#7)
Here's one with 16 pieces
PostPosted: Tue Feb 26, 2013 5:25 am  (#8)
Nice job Graechan.
PostPosted: Tue Feb 26, 2013 5:24 pm  (#9)
I used the fuzzy select tool on the channel because it works
PostPosted: Tue Feb 26, 2013 6:58 pm  (#10)
Jeepers Graechan, you make everythang look so easy.
PostPosted: Tue Feb 26, 2013 7:14 pm  (#11)
I am glad to see others giving this a try. i really think that doing things like this, works the mind and from what i have read, that can keep your mind working right for years to come. i have seen where people that do puzzles or mind games through there life can keep Alzheimer's disease from taking effect during there old age. at some point i will post mine. and from what i have seen, mine will be different from what has been already posted.
PostPosted: Tue Feb 26, 2013 8:08 pm  (#12)
Molly it was not difficult as I used puzzler
Puzzler.scm [4.66 KiB]
Downloaded 248 times
PostPosted: Tue Feb 26, 2013 10:51 pm  (#13)
sorry it has a dependancy 'layer via cut' sorry done for expediancy I'll get rid of it now
Download and try again now OK
PostPosted: Tue Feb 26, 2013 11:50 pm  (#14)
It was good fun!
bbbbbbbbbbbImage
PostPosted: Wed Feb 27, 2013 12:03 am  (#15)
Nicely done Akros yours was definitely different
PostPosted: Wed Feb 27, 2013 4:51 am  (#16)
Very good Akros...cute picture
PostPosted: Wed Feb 27, 2013 5:28 am  (#17)
I must have downloaded the wrong script cuz I don't have any options where I can choose which pieces go in a special order.
PostPosted: Wed Feb 27, 2013 6:06 am  (#18)
Graechan thx! I wanted to try something really different. I had fun putting a piece into the slot wrong, and then fixing.
Molly thx!, well ... in my case I did not use plugins. Only the Gimp and the fuzzy filter board. The choice of the order was manually.
bbbbbbbbbbbImage
PostPosted: Wed Feb 27, 2013 6:09 am  (#19)
If you did it manually, you must have got the puzzle layout in the regular menu...then did you select them in the order you wanted them to go in?
PostPosted: Wed Feb 27, 2013 6:52 am  (#20)
Molly,
Do not know if I got it right ... :puzzled
But I used Filter> Decor> Fuzzy Border, then manually cut out the puzzle and chose the order that would be assembled, did that just ordering the layers.
Tip: This video covers the topic well http://youtu.be/KSRFFFseQZM
bbbbbbbbbbbImage
