It is currently Wed Sep 30, 2026 8:23 am
 Post subject: Becker BK Evolution: A Metamorphosis
PostPosted: Sun Jun 02, 2013 11:48 pm  (#1)
I'm a huge Becker Knife and Tool knife fan. I'm the outdoorsy type, and frequent many outdoor themed forums. Ethan Becker is the author of "The Joy of Cooking", the number one selling cookbook in the world. He also happens to be an outdoor enthusiast, and designed the Becker Patrol Pack, that used to be used by the Navy SEALS. He also has a series of knives he has designed. He has designated them BK1, (Becker Knife 1)BK2, etc. Anyways, as sort of a tribute, I decided to morph all of his designs into one animation. Not hard to do per se, but very time consuming. By the way, I later decided to add my user name, and didn't know how to add it to all the frames at once, and did it by the frame...all 435, haha:
 Post subject: Re: Becker BK Evolution: A Metamorphosis
PostPosted: Mon Jun 03, 2013 12:06 am  (#2)
This is pretty cool.
PostPosted: Mon Jun 03, 2013 1:21 am  (#3)
[quote="The Warrior"]I'm a huge Becker Knife and Tool knife fan. I'm the outdoorsy type, and frequent many outdoor themed forums. Ethan Becker is the author of "The Joy of Cooking", the number one selling cookbook in the world. He also happens to be an outdoor enthusiast, and designed the Becker Patrol Pack, that used to be used by the Navy SEALS. He also has a series of knives he has designed. He has designated them BK1, (Becker Knife 1)BK2, etc. Anyways, as sort of a tribute, I decided to morph all of his designs into one animation. Not hard to do per se, but very time consuming. By the way, I later decided to add my user name, and didn't know how to add it to all the frames at once, and did it by the frame...all 435, haha:
That's really cool!
If you only knew then what you know now.
:hehe
PostPosted: Mon Jun 03, 2013 8:51 am  (#4)
Thanks guys, appreciate it.
PostPosted: Mon Jun 03, 2013 9:06 am  (#5)
Nice blending! Very skillfully done!
You could use AnimStack script for adding stuff to background/foreground.
It's quite versatile script for animation purposes and it's quite unique.
PostPosted: Mon Jun 03, 2013 9:25 am  (#6)
Ditto ^^^...nice job Warrior
PostPosted: Mon Jun 03, 2013 9:50 am  (#7)
Thanks everyone, I appreciate it.
Could you please link me to this? Any tuts around for it? Thanks.
PostPosted: Mon Jun 03, 2013 10:08 am  (#8)
http://registry.gimp.org/node/26501
Nicely done!
I just bought the Becker BK2 with the newer sheath (less glass inside so it doesn't dull the edge on release).
Man that thing is a... to quote David Cantabury "A Becker Train Wrecker" :lol
I can't wait to play with it this summer. The thing is like a pry bar. :) Kinda heavy though, and i think i will change the sheath.
PostPosted: Mon Jun 03, 2013 10:15 am  (#9)
Nicely done!
Thanks!
The BK2 was my first, and is a beast of a blade. I have 2 BK2's, one stock, one I modded into a clip point.
Stock:
Modded. also shows my sheath mod:
PostPosted: Mon Jun 03, 2013 10:22 am  (#10)
Using Saulgoodes combine bg would do the trick for you. :bigthup
Just a bg layer all black except your name and run the script.All layers will get that bg.Then delete the bg layer (original)
The combine bg can be found here - http://chiselapp.com/user/saulgoode/rep ... 7a3fba231f
PostPosted: Mon Jun 03, 2013 10:24 am  (#11)
Wallace led me in that direction. viewtopic.php?f=25&t=2243&start=60#p95002
Kind of why I posted this animation. Sure do wish I had that then.
PostPosted: Mon Jun 03, 2013 10:31 am  (#12)
That is sweet looking.Did you use mustard for the blade? Cool tiger stripe design.I have to take the black coating off mine yet.I think G10 handles are in the future for mine.That or wood.Not sure yet. :)
PostPosted: Mon Jun 03, 2013 10:36 am  (#13)
It's actually gun bluing. I took the scales off, stripped the blade, cleaned it well, applied a coat of bluing, sanded it off lightly. Then, I laid down some blue painters tape down on some wax paper. Traced the knife onto the tape. Drew the stripes, cut them out with an exacto knife, and placed the tape on the knife. Applied gun blue again, took the tape off, and steel wooled it lightly.
I used cut out tape on the scales as well, and painted them.
By the way, The Knife Connection has some nice G10. Pricey, but nice: http://www.the-knife-connection.com/bec ... 7--9-.html
PostPosted: Mon Jun 03, 2013 10:43 am  (#14)
By the way, The Knife Connection has some nice G10. Pricey, but nice: http://www.the-knife-connection.com/bec ... lades.html
Thanks for the information and the link.I may check out their scales.Thinking of making my own with cloth and epoxy. Looks kinda messy though. :lol
PostPosted: Mon Jun 03, 2013 3:10 pm  (#15)
No problem. I purchased some California Buckeye Burl scales for mine. I made a sheath in GIMP, and won a contest with it. The guy is going to make the sheath I designed, so I'm going to strip the blade, and put the wood scales on my other 2.
PostPosted: Mon May 19, 2014 12:22 am  (#16)
I used the becker knife for Shaving and whittling and I was like wow.
I did all of these test after the battening and chopping.
The knife shaved the wood like hairs. I was able to shave thin enough tinder to start a fire. I was also able to whittle down wood to make a somewhat dead fall (I need A LOT of work in this area) I was able to carve with little effort.
PostPosted: Mon May 19, 2014 4:58 am  (#17)
May 19 Link missing or removed on this post Warrior.
June - 6 EDIT: dead image link removed.
