It is currently Tue Nov 17, 2026 12:43 am
 Post subject: Inkscape-1.5 - beta
PostPosted: Fri Oct 18, 2024 4:06 pm  (#1)
Every commit i've tried as a zip has failed to load the welcome screen without a crash. Anyone know which zipped file for Windows x64 to download that works?
Actually if i load with the debug cmd window (batch file), it loads the cmd screen then loads an Inkscape window that has nothing on it. Almost as if the GTK isn't the correct version.
 Post subject: Re: Inkscape-1.5 - beta
PostPosted: Sat Oct 19, 2024 12:19 am  (#2)
I have decided to try and compile for Windows. I'll keep you all updated.
PostPosted: Sat Jun 14, 2025 12:44 am  (#3)
Finally got Inkscape-1.5 to work. I think possibly it will not work in Windows 10. It does in Windows 11 apparently. :)
