It is currently Tue Nov 17, 2026 4:59 am
 Post subject: SIF (Synfig) exporter extension for Inkscape
PostPosted: Fri Aug 19, 2011 10:51 pm  (#1)
https://github.com/nikitakit/svg2sif/zipball/master
https://github.com/nikitakit/svg2sif/tarball/master
SIF exporter extension for Inkscape
svg2sif is an Inkscape extension that converts SVG files to Synfig Animation Studio (.sif) files.
Installation
Place the extension files (.py and .inx) in one of the following locations
To install for all users (may require root or administrator privileges)
* Windows: "C:\Program Files\Inkscape\share\extensions"
* Linux: "/usr/share/inkscape/extensions"
* Mac OS X: "/Applications/Inkscape.app/Contents/Resources/extensions"
To install for one user only:
* Windows: "C:\Documents and Settings\user\Application Data\Inkscape\extensions"
* Linux: "/home/user/.config/inkscape/extensions"
* Mac OS X: "/Users/user/.config/inkscape/extensions"
Usage
svg2sif adds a "Synfig Animation (*.sif)" option to Inkscape's "Save As" dialog.
If your SVG document contains clones or non-paths (text, rectangles, etc.) the extension will quickly open another Inkscape window to convert these elements to paths. This may take a while. The file is not saved until the status bar reads "Document Saved."
If you save frequently, you can speed up the process by selecting "Extensions>Synfig>Prepare for Export" from the Inkscape menu. This will convert everything in the current document to paths (but may make it harder to edit).
