It is currently Tue Nov 17, 2026 4:33 am
 Post subject: I just found a test version of Inkscape-0.48.3.1 (Windows)
PostPosted: Sat Mar 24, 2012 9:23 pm  (#1)
Just downloaded and installed it into its OWN new directory (Inkscape_NEW)
Just so i do not mess up my stable version. :)
It is supposed to have mesh gradients added now.More information here.
http://libregraphicsworld.org/blog/entr ... w-official
You can download the test beta exe file here - Windows skydrive - you will probably need to login.
(install into a different directory other than your Inkscape-0.48.2 version)
https://skydrive.live.com/?cid=09706D11 ... 52A%21190#
I will let you know what i think. :)
 Post subject: Re: I just found a test version of Inkscape-0.48.3.1 (Windows)
PostPosted: Sat Mar 24, 2012 9:51 pm  (#2)
Installed it yesterday; should have un-installed the old version and deleted the directory like they recommended. It took over 45 minutes to install and I suspect that's why it did so. Works great though; single Window now; guess that's they way things are going. Only use Inkscape as a glorified filter anyway, since I'm mainly a GIMPer. :)
PostPosted: Sat Mar 24, 2012 10:08 pm  (#3)
That is wicked Rod; so the filters dynamically change when you move an object then? Way too wack. lol
PostPosted: Sat Mar 24, 2012 10:15 pm  (#4)
Actually i did not know this was already available in 48.2 :)
I discovered something new. :lol
I do believe the gradients look more realistic now though.
PostPosted: Sat Mar 24, 2012 10:18 pm  (#5)
This is out of Inkscape-0.48.2 :)
PostPosted: Sat Mar 24, 2012 10:21 pm  (#6)
Works with any grouped objects apparently Rod. I used the edit path by nodes to shift one of the objects within the group around. :)
PostPosted: Sat Mar 24, 2012 10:24 pm  (#7)
I never even knew this was possible in Inkscape before now. :lol
Its like taking waterdrops and pushing them together. Pretty cool stuff!
