It is currently Tue Nov 17, 2026 4:32 am
 Post subject: Do many of you use InkScape
PostPosted: Mon Jul 09, 2012 8:54 am  (#1)
as a separate application or do you find Gimp enough?
 Post subject: Re: Do many of you use InkScape
PostPosted: Mon Jul 09, 2012 9:04 am  (#2)
Strangely enough I keep downloading updates but never use it. I might have a go one day but I find Gimp does most things I want graphics software for.
PostPosted: Mon Jul 09, 2012 9:08 am  (#3)
But they have different uses. Bitmap and vectors.
I use Inkscape in a very basic way. To make some logos or icons. Things do not lose resolution when resized.
PostPosted: Mon Jul 09, 2012 12:02 pm  (#4)
I don't use it a lot but it's a good tool to have handy.
Along with what's already mentioned, Scalable Vector Graphics (SVG), wire-framing, maps...
PostPosted: Mon Jul 09, 2012 12:37 pm  (#5)
I used to design an entire company's handouts and folders for multiple banquets and conferences.
PostPosted: Mon Jul 09, 2012 12:52 pm  (#6)
Don't get Gimp and Inkscape confused. Gimp works with bitmaps and inkscape works with vectors. If you don't understand the difference, don't feel bad, a lot of people don't. Think of a bitmap as a grid of squares drawn on paper, you fill in each square wit a color. That's why some graphics have jaggy edges. Bitmaps are like what you get from a camera or scanner. Like a photo, they can and usually have several colors and are complex. The problem is that if you try to scale them up or down too much they fall apart. That's their big downfall, they also have really big file sizes.
NOW, consider a vector as a piece of paper with mathematical instructions on it telling us to 'draw a line from this point to that point', simple. You can scale a vector up or down almost infinitely. Vectors usually have less colors and smaller file sizes. If you make graphics it's good to have them both. if all you do is edit photos you don't need a vector program. Personally, I can't get by without having both, they each have their uses, strengths and weaknesses.
PostPosted: Mon Jul 09, 2012 1:43 pm  (#7)
I always download but i never used (in years i would have opened 3 or 4 times )
I found so unintuitive vector graphic programs, so i never use, but i always plan to start using
PostPosted: Mon Jul 09, 2012 2:55 pm  (#8)
Vectors have to be treated and seen differently than bitmaps. I started using Xara 5 and even though it was expensive I use inkscape more. There are things one ca do much better with vectors than bitmaps.
PostPosted: Mon Jul 09, 2012 3:50 pm  (#9)
Yes and in combination they make a suite that is very good in terms of graphic design for the open source junkies such as me :D
PostPosted: Mon Jul 09, 2012 5:57 pm  (#10)
I mostly use inkscape when I want to draw paths freehand. I then import the paths to gimp and colour/stroke them with gimp.
I really like inkscape's freehand path tool, it's something that I wish I could do directly in gimp... yes, there's the selection to path tool but it's not the same - only works for closed paths and is way less accurate.
PostPosted: Tue Jul 10, 2012 2:09 am  (#11)
Thanks sweetheart....very clear way of putting it :)
PostPosted: Tue Jul 10, 2012 4:19 am  (#12)
Made my avatar with it. :)
Plus a few other things.
A wine bottle using node sculpting.
viewtopic.php?f=22&t=1980&hilit=inkscape
I use it constantly along with Gimp. For path creation, trace bitmapping, and vexel art creation (node sculpting).
PostPosted: Tue Jul 10, 2012 4:26 am  (#13)
very nice job of that bottle Rod.
I don't use Inkscape. I find it difficult to learn and I have enough on my plate just to learn Gimp, and all the new scripts etc. I am not what a person would call a multi-tasker lol.
PostPosted: Tue Jul 10, 2012 10:16 am  (#14)
Inkscape is excellent for node sculping, by far the best thing I've tried. It's better than the expensive Xara Extreme.
PostPosted: Tue Jul 10, 2012 10:30 am  (#15)
Inkscape can do nice work. Here are two examples, one drawn in Gimp and the same thing draw in Inkscape Here are two more good examples: Bowling pin and a Gear.
PostPosted: Tue Jul 10, 2012 10:54 am  (#16)
I agree Molly and Rod I love your avatar.
Thanks guys for all your views, very interesting :)
PostPosted: Tue Jul 10, 2012 11:33 am  (#17)
I use Inkscape regularly too. It's excellent for particular types of images, icons and logos, but I also use it for maps and diagrams. Plus you can vectorize bitmaps very well in it (for large-scale printing and the like; I made a 8x5 meter large print once - meant to be viewed at close range. Try getting a bitmap image that size in a decent resolution (yes I tried, when GIMP on a 16GB RAM machine couldn't handle it I decided a vector image was really the way to go).
Inkscape is also still far superior for laying out comic frames and text (even though latest GIMP is improving); I have a tutorial for my workflow combining Inkscape, MyPaint and GIMP here for those interested.
Griatch
PostPosted: Tue Jul 10, 2012 3:28 pm  (#18)
It does vectorize VERY well, better than some commercial software.
PostPosted: Thu Jul 12, 2012 1:35 pm  (#19)
I do all my vector work in inkscape then bring that into gimp for layer compositing and painting.
-Rob A>
PostPosted: Sat Jul 28, 2012 7:50 pm  (#20)
Another nice thing about Inkscape and Gimp is the fact that they can use each others resources up to a certain point.
Gimp can use SVG gradients from Inkscape.
Gimp can use Inkscapes Pallet files also.
What would be really cool is to see Inkscape open XCF files in the future. :)
