It is currently Tue Nov 17, 2026 4:31 am
 Post subject: FIRST Steps
PostPosted: Tue Dec 25, 2012 12:53 am  (#1)
so after watching the 20th heathenX screencast, i finally found something interesting enough to try
its nothing great, but hopefully good enough to post
the shaped text comes from this screencast:
http://screencasters.heathenx.org/wp-co ... ep060.html
and i combined it with a grunge texture made in Gimp
the most difficult part was getting all the objects in the right order
im really missing Gimp layers in Inkscape
i know IS has layers too, but they are different
 Post subject: Re: FIRST
PostPosted: Tue Dec 25, 2012 5:19 am  (#2)
Excellent Esper, very effective. I love the grunge texture
PostPosted: Tue Dec 25, 2012 5:36 am  (#3)
thanks molly, i´ll post it, in case somebody has a use for it
PostPosted: Tue Dec 25, 2012 5:54 am  (#4)
and i recreated a little logo in Inkscape and bump-mapped/finished it in Gimp
 Post subject: Re: FIRST Steps
PostPosted: Tue Dec 25, 2012 6:35 am  (#5)
Nice, thanks for the grunge.
PostPosted: Tue Dec 25, 2012 12:01 pm  (#6)
Nice and neat effects, Esper!
Have you installed any 3rd Filters and Extensions to Inkscape?
If not, check out extensions repository on Inkscape Wiki.
You might find some of them useful.
PostPosted: Tue Dec 25, 2012 2:32 pm  (#7)
no i havent K1Te
i had a long thought about your post in the other thread
im a bit reluctant to broaden my palette of tools so to speak but i will try to combine the best of Gimp and Inkscape in the future
maybe i will try the extensions when i need them
PostPosted: Tue Dec 25, 2012 8:23 pm  (#8)
wanted to use the logo made in Inkscape today and make a cover with it in GIMP
fiddled around a bit, and after a while i realized everything i wanted to do with the text, would be much easier in Inkscape....
so i said: listen Gimp-baby, you must be strong now, you are no longer the only one
pls dont be angry with me, i will just bump-map this logo with you and then go to this other program...
no, dont cry, i will come back - promise !
i really love you
EDIT: btw, i didnt realize this cover accidentally represents what i did
this is an old record from 1999, the guy who made it, really goes by the name of Perfect Combination and the track was really called Technical Switch, its not symbolic for my struggle changing programs, lol
