It is currently Tue Nov 17, 2026 4:31 am
 Post subject: vector imagery
PostPosted: Mon Mar 18, 2013 6:56 pm  (#1)
Ello all. Im trying to make something in inkscape and i am having issues. I am trying to make this
I have imported a jpg and embeded it. i use the trace feature, select colors, 38 scans and it does not look as ood as some of these awesome art pieces. such as above and
http://wallpapers-diq.com/wp/90__The_Be ... _Face.html
mine look all weird and stuff. how should i accomplish this task?
thanks
 Post subject: Re: vector imagery
PostPosted: Tue Mar 19, 2013 4:27 am  (#2)
@LT72884...it is strange but your image doesn't show up in my pc. Try uploading it with this button.Image
PostPosted: Tue Mar 19, 2013 11:19 am  (#3)
thanks
For starters I wouldn't use 38 scans with colors. Don't use colors or reduce the scans or both. Why exactly are you tracing the jpg? Are you sure bitmap tracing is the right tool to use?
PostPosted: Tue Mar 19, 2013 11:35 am  (#4)
Source code shows that image exists, maybe a bad embedding, here is the correct link:
PostPosted: Tue Mar 19, 2013 10:13 pm  (#5)
thanks
You will never get results as good as the wallpaper link provided with any kind of automated bitmap trace. That image (and other high quality vectors ) are done by hand, using a photo as a reference to draw over.
Check http://www.inkscapeforum.com/ for some vector tutorial links.
-RobA>
