It is currently Tue Aug 18, 2026 2:19 am
 Post subject: G'MIC teaser slides
PostPosted: Fri Mar 21, 2014 4:16 pm  (#1)
Hi there,
Patrick David has helped a lot to make these three "teaser slides" for the G'MIC project talk at the Libre Graphics Meeting 2014.
I think it is worth sharing :) (I've reduced the resolution a little bit before posting).
Now, are you really sure you don't want to come to LGM ? :D
 Post subject: Re: G'MIC teaser slides
PostPosted: Fri Mar 21, 2014 4:55 pm  (#2)
Awesome slides and hope your presentation received the accolades that it deserves David. :)
PostPosted: Fri Mar 21, 2014 8:32 pm  (#3)
:jumpclap
PostPosted: Fri Mar 21, 2014 9:32 pm  (#4)
Very nice.
Might I suggest changing the question mark after "2013" to an exclamation mark. Since that year is over, there is little question as to what it offered.
PostPosted: Fri Mar 21, 2014 9:50 pm  (#5)
Ronounours wrote:
Hi there,
Have you tried, Impressive?
PostPosted: Sun Mar 23, 2014 10:36 am  (#6)
Looking good!
The additions of patch-based inpaint and script controlled parallel really are big leaps forward, it's easy to take them for granted now that they work so well.
Hope the presentation goes well ;)
