It is currently Thu Nov 19, 2026 11:18 am
 Post subject: G'MIC plug-in : New filter 'Arrays & tiles / Ascii art'
PostPosted: Wed Mar 26, 2014 12:18 pm  (#1)
Hello there,
Another day, another filter :)
I've added a new filter Arrays & tiles/Ascii art in the G'MIC plug-in for GIMP. This is a first version, so there are probably lot of amelioration to do, but this gives already interesting results. Note that you will probably need the latest version 1.5.8.5 of the plug-in to make it working flawlessly.
Anyway, if someone can test with an older version, please tell me how it behaves :)
The interesting thing is that you can choose the 'charset' used for the analysis, so you can customize your rendering a little bit.
Some examples follow. First, the filter as you can get it after a filter update (as always, press the 'Update filters' button) :
Then, an example of 'standard' rendering, with the usual ASCII charset. Note that the letters can be optionally colorized with colors from your input image
(done with the 'shape average' blending mode that Lyle uses a lot if I remember well :) ).
Now, if you choose a custom charset, you can render things like this, where the letters used for the rendering are actually the letters of the people names.
(the left image has been colorized, but not the right one).
Well that's it for now, let me know if you have some experiments or additional suggestions for this filter.
Cheers,
David.
 Post subject: Re: G'MIC plug-in : New filter 'Arrays & tiles / Ascii art'
PostPosted: Wed Mar 26, 2014 12:50 pm  (#2)
very well done, thanks David!
PostPosted: Wed Mar 26, 2014 3:29 pm  (#3)
Wow, this is awesome. Thanks for all your hard work, appreciate it.
PostPosted: Wed Mar 26, 2014 4:20 pm  (#4)
Definitely cool David; is there a way to export the actually text file? :)
PostPosted: Wed Mar 26, 2014 4:36 pm  (#5)
Finally figured out how to get a higher density (stupid I am I suppose). lol
https://www.flickr.com/photos/34520999@N05/13434284203/sizes/o/
PostPosted: Wed Mar 26, 2014 4:58 pm  (#6)
To get a higher density, you can lower the 'analysis scale' parameter, but I would rather recommend simply to upscale your image before converting it to ascii art. Having a too low analysis scale will give you a result with less precision.
Having an export option for an ascii file is indeed an excellent idea, I'll add it tomorrow.
PostPosted: Wed Mar 26, 2014 5:11 pm  (#7)
Thanks David; I did actually play with the analsysis scale then resized. Guess it would have been just as easy to resize the image, run the preset, then downsize back. lol
PostPosted: Wed Mar 26, 2014 5:24 pm  (#8)
Lyle, I've just added the 'Export as ascii file' option. You must set a valid path there to make it working, but this should be OK
(at least, it works on Linux :p ).
Let me know !
PostPosted: Wed Mar 26, 2014 5:43 pm  (#9)
It works David. Thanks. Would also be cool to add a check box too so you can have a permanent path and then when you want to export the text, just click the box. :)
PostPosted: Wed Mar 26, 2014 5:52 pm  (#10)
Where does it export to? Can't seem to get the export to work. I'm probably doing something wrong.
PostPosted: Wed Mar 26, 2014 6:06 pm  (#11)
Let me know !
Didn't see this. Got it. Works great on Windows too, thanks.
PostPosted: Wed Mar 26, 2014 6:22 pm  (#12)
Something like this would be better ?
PostPosted: Wed Mar 26, 2014 6:24 pm  (#13)
That's Excellent!
PostPosted: Wed Mar 26, 2014 6:30 pm  (#14)
Very cool. Export as ascii works too. :bigthup
PostPosted: Wed Mar 26, 2014 6:46 pm  (#15)
I've just done some additional optimizations to make it a little bit faster (still slow anyway).
I think I'll stop for now, it's already 00:44am here, and I feel a bit tired :)
PostPosted: Wed Mar 26, 2014 7:06 pm  (#16)
Your work's done now David. Get a good nights sleep now. lol
thanks.7z [36.87 KiB]
Downloaded 395 times
PostPosted: Wed Mar 26, 2014 7:08 pm  (#17)
I guess (well know) I no longer need ASCII-Gen. lol
PostPosted: Wed Mar 26, 2014 11:50 pm  (#18)
David and Lyle There's no 64bit file on SourceForge as yet I have it from Samj's site for those who would like it
gmic-1585-full-win-32bits-64bits
PostPosted: Thu Mar 27, 2014 9:30 am  (#19)
Applying this filter on multiple layers is cool too ! :D
https://www.youtube.com/watch?v=11NJlqqOklc
PostPosted: Thu Mar 27, 2014 10:53 am  (#20)
That is so cool. :bigthup
