It is currently Thu Aug 20, 2026 9:45 pm
 Post subject: New G'MIC filter : 'Patterns / Resynthetize texture'
PostPosted: Wed Apr 09, 2014 11:22 am  (#1)
Hello there !
LGM 2014 is now over, so it is time to go to work again :hehe
So, today Jérome Boulanger and I have coded a new filter Patterns / Resynthetize texture for the G'MIC plug-in that might interest you.
It basically tries to resynthetize an input texture into an image of arbitrary size. It uses a phase randomization technique in
the Fourier space to achieve the texture synthesis.
After updating your filters (requires at least G'MIC version 1.5.8.0), you should be able to select it and see this :
You have only two parameters that tell about the desired size of the synthetized output texture.
Below I show an example of what you can achieve with this filter. The input sample textures are not tileable, while the
synthetized outputs are (FFT property). Here, I've just doubled the image size, but of course, you can set any size you want.
Note that it works quite well with micro-textures, but definitely not with macro-textures. You have been warned :)
Also note that the filter is already parallelized, so it should use the multiple cores of your machine when possible.
Now, it's your turn, if you want to play you are welcome to post what you obtain with this filter and tell us if this can be useful and in which cases.
Enjoy !
:tyspin
 Post subject: Re: New G'MIC filter : 'Patterns / Resynthetize texture'
PostPosted: Wed Apr 09, 2014 1:07 pm  (#2)
Excellent, thank you very much.
PostPosted: Wed Apr 09, 2014 1:35 pm  (#3)
Will have to play around with this a bit more.
Do you "have to" have something on your canvas before anything happens? I found I had to.
PostPosted: Wed Apr 09, 2014 2:00 pm  (#4)
Hi David.
I did some trials, but I did not get what expected.
I mean, looking at your examples, it seems the original texture is almost kept, while in my tests it's very distorted.
What did I wrong?
starting size is 128x128, resulting (default) 1024x1024
thanks
PostPosted: Wed Apr 09, 2014 2:58 pm  (#5)
dinasset, please provide only micro textures, which means textures with fine grain and no complex patterns (brick walls e.g are complex patterns).
It won't work at all with macro textures. All the textures you provided can be considered as macro-textures.
PostPosted: Wed Apr 09, 2014 5:29 pm  (#6)
Online
No bricks then; still pretty cool since seamless texture is a side hobby of mine.
SSP below (shameless self promotion; lol). :)
http://lylejk.deviantart.com/gallery/
PostPosted: Wed Apr 09, 2014 6:05 pm  (#7)
another great and useful filter
thank you !!
whats really great about this is, you get organic looking textures, without the synthetic look of a tiled pattern
PostPosted: Thu Apr 10, 2014 1:20 am  (#8)
I ran this filter over most of my patterns to see what would happen.
PostPosted: Thu Apr 10, 2014 2:20 am  (#9)
Online
Anyway possible to add a patch size slider so that we can choose a larger patch size for creating the texture? :)
PostPosted: Thu Apr 10, 2014 6:31 am  (#10)
lylejk, I took a look in your gallery. The textures are magnificent. Thanks for sharing.
PostPosted: Thu Apr 10, 2014 6:40 am  (#11)
Lyle, the synthesis algorithm does not use patches at all, so this is not possible :mrgreen:
PostPosted: Thu Apr 10, 2014 3:16 pm  (#12)
Online
Thanks Carlos; they are free for all to use.
OK David; still, I do see some cool use for certain types of textures so do appreciate it. Just created this black leather texture from a single lego block. :)
PostPosted: Sun Apr 13, 2014 10:14 am  (#13)
Online
Here's a thought David for you next hat trick. Some of the textures people rendered and shared in this thread remind me of stereograms (SIRDS) renders (you know; magic eye for parallel view 3D). Maybe G'MIC can be coaxed to create these type renders. Currently I use a very old (but still works in GIMP) plugin to create them in GIMP. :)
PostPosted: Sun Apr 13, 2014 3:35 pm  (#14)
There is one already, made my Tom Keil. It's under "Stereoscopic 3D -> Single image stereogram" but for some reason isn't working for me. It definitely used to work though so should be fixable.
PostPosted: Mon Apr 14, 2014 11:21 am  (#15)
Online
I've seen this one before too GC but it's never worked for; not sure what broke it but by the time I've tried using it (may have been a year ago) it just doesn't work. :)
PostPosted: Mon Apr 14, 2014 12:05 pm  (#16)
This has been fixed. Thanks for reporting. :)
PostPosted: Mon Apr 14, 2014 2:16 pm  (#17)
Online
Maybe a dot guide would help; tried to create one and at least the distorted result isn't there anymore but I'm having issues seeing the 3D image whereas other SIRDS (like the wiki example) comes out quite clear to me. :)
PostPosted: Mon Apr 14, 2014 2:26 pm  (#18)
Honestly, I try to maintain the filters done by Tom Keil as much as I can, but I've never participated in the design of those filters, and adding new features to them is probably out of my knowledge. I'm not familiar with stereo images as well. Unfortunately, despite my trials, I haven't got news from Tom since months (years?) and I'm afraid he won't touch these filters anymore. I hope I'm wrong anyway.
PostPosted: Wed Apr 16, 2014 7:22 pm  (#19)
When I refresh the filters for the Windows version.
I get an error message.
Is this update only apply for Linux versions?
PostPosted: Wed Apr 16, 2014 7:37 pm  (#20)
All platforms.
Current G'MIC for GIMP
