It is currently Tue Aug 11, 2026 1:55 pm
 Post subject: Release of G'MIC 1.5.9.3
PostPosted: Sat Jun 21, 2014 4:20 am  (#1)
Hello there,
It's summer time, time for a new G'MIC release :)
I'm happy to announce the release of the version 1.5.9.3 of the G'MIC image processing framework, including an updated version of the plug-in binaries.
It should be already available for Windows and Linux users.
Here is a link to the Changelog : https://www.flickr.com/groups/gmic/disc ... 044963651/
The main improvement in this version is the addition of multi-threaded operations in native commands through OpenMP. Lot of G'MIC native commands are impacted.
That means, if you have a computer with multiple cores and you want to process 'big' images (>1024x1024), you will probably get a visible speed boost!
A quick and easy way to test the advantage of this OpenMP-based released is to try the filter Repair / Smooth [median], this is one that is definitely faster.
I hope you'll enjoy it. Time for some holidays now :)
Cheers,
David.
 Post subject: Re: Release of G'MIC 1.5.9.3
PostPosted: Sat Jun 21, 2014 4:27 am  (#2)
Thank you very much
PostPosted: Sat Jun 21, 2014 4:42 am  (#3)
Thank you Ronounours :hi5
:gimp
PostPosted: Sat Jun 21, 2014 5:10 am  (#4)
just a small info for 32-bits windows users
the downloaded package does not include libwinpthread-1.dll
I got it back from a previous release
now gmic 1.5.9.3 starts
PostPosted: Sat Jun 21, 2014 5:16 am  (#5)
Thanks Dinasset. My boy thanks you too.;}
PostPosted: Sat Jun 21, 2014 6:35 am  (#6)
Thank you Ronounours. Hopefully it will fix my issue.
Now I don't have a G'MIC in my gimp at all. :(
PostPosted: Sat Jun 21, 2014 8:28 am  (#7)
great
appreciate that!
PostPosted: Sat Jun 21, 2014 8:30 am  (#8)
sallyanne : go download it again, I've just added the missing .dll in the installation package.
Sorry about that.
PostPosted: Sun Jul 27, 2014 7:48 pm  (#9)
'O' try this http://gmic.eu/
PostPosted: Sun Jul 27, 2014 9:56 pm  (#10)
Thank you, Graechan. :hugme
I finally backed out of the new hd and went back into the old to get the path.
PostPosted: Sun Jul 27, 2014 10:15 pm  (#11)
I have the 1.5.9.3 already. When will the 1.6.0.0 version be available for windows 64 bit?
PostPosted: Mon Jul 28, 2014 3:02 am  (#12)
It will be available when it's ready :)
Version 1.6.0.0 is intended to be a major release, so I'll wait probably that we have enough new stuffs in it before releasing it.
PostPosted: Mon Jul 28, 2014 3:10 am  (#13)
I look forward to that. Thank you.
PostPosted: Mon Jul 28, 2014 4:15 am  (#14)
Sorry but I am not sure where I can download this from, thanks :)
PostPosted: Mon Jul 28, 2014 5:18 am  (#15)
Hi Deblk
you can download it here: http://gmic.eu/
and here the original Homepage http://gmic.eu/
greetings
groni
I am comfortable with Linux as a penguin in the water
A Day without working with Gimp is a very very bored Day (groni g)
