It is currently Sat Nov 28, 2026 1:49 pm
 Post subject: [G'MIC] New filter 'Colors / Curves [interactive]'
PostPosted: Thu Oct 09, 2014 2:26 pm  (#1)
Hi there,
I've coded a new filter for the G'MIC plug-in, trying to extend the color curves tool for many more colorspaces, including Lab, HSV, CMYK, etc..
If you have at least the version 1.6.0.1 of the plug-in, you can access it after updating your filters.
I've recorded a very quick video to show how it works (here, for a curves manipulation in the CIE Lab colorspace) :
Once you are happy with your curves, you can add this filter to your Faves, and the color preset will be remembered next time.
Let me know if you find it useful !
 Post subject: Re: [G'MIC] New filter 'Colors / Curves [interactive]'
PostPosted: Fri Oct 10, 2014 6:59 am  (#2)
Ronounours, please, from which link can Iget the installer for version 1.6.0.1 of G'MIC for Win32? At the official website of G'MIC there is no indication on the version.
PostPosted: Fri Oct 10, 2014 7:22 am  (#3)
This link shows under the black bar at the top that this is the stable version of 1.6.0.1
The top one would be for windows 32 and 64
http://gmic.eu/
PostPosted: Fri Oct 10, 2014 7:24 am  (#4)
Thanks, Molly.
PostPosted: Fri Oct 10, 2014 7:30 am  (#5)
Carlos, all versions available in the G'MIC web site are at least 1.6.0.1 for the proposed architectures.
PostPosted: Fri Oct 10, 2014 7:39 am  (#6)
Thanks, Ronounours
PostPosted: Fri Oct 10, 2014 7:41 am  (#7)
The possibility of having interactive filters on G'MIC is really wonderful. This has great potential. Thank you David.
Do you know about Darktable? If you could implement Darktable Equalizer (Luminance/Chrominance/Edges) and Color Zones filter would be great :)
Playing with the filter (plus vignetting):
http://pixabay.com/es/punta-trigo-cerea ... ampo-8742/
PostPosted: Fri Oct 10, 2014 10:43 am  (#8)
Looks cool indeed. Hopefully someone can come up with some cool presets like Photochrom.
PostPosted: Fri Oct 10, 2014 11:04 am  (#9)
Curves [interactive] is exactly what I wanted David. It's way better than going the decompose/recompose route for channels adjustments and these Interactive methods are excellent to work with.
PostPosted: Fri Oct 10, 2014 11:50 am  (#10)
Thanks Odin.
And the very good thing (in my opinion), is that you can also output a so-called 'CLUT' file, which remembers all your color transformations, and which can be used in other softwares as well (e.g. RawTherapee).
If you have nice color presets you've done and you want to share, then this is a convenient way (albeit not the smallest one) to do it. Just save the CLUT file and share it with others. G'MIC has also a filter to apply an arbitrary CLUT file (located in 'Film emulation/' if I remember well).
PostPosted: Sat Oct 11, 2014 1:20 am  (#11)
:clap This is a great filter!
I've played with it this morning.
Thank You!
PostPosted: Sat Oct 11, 2014 1:35 am  (#12)
David your spoiling us with all these fantastic Gmic interactive goodies, Thank you for turbocharging Gimp
PostPosted: Sat Oct 11, 2014 11:06 am  (#13)
This is simply amazing David. Thank you for adding these interactive window filters. They are fantastic.
PostPosted: Sat Oct 11, 2014 6:14 pm  (#14)
Thanks David!
You are making a good use of the interactive window. Love this new gmic feature as I said before.
Curves is a powerful tool. I use it to make a tonal and color corrections, even prefer Curves to Brightness/Contrast
tool to make corresponding adjustments.
A few suggestions that I believe would make the new filter even greater.
1. Clicking on image would create a curve point on each separate channel curve. Say you can assign LMB click
for color picker sampling and leave RMB for before/after split view. Well, this is a very important functionality in the Curve tool*.
2. There's gotta be a way to reset curves to the initial state without closing interactive window.
3. The possibility to delete points.
4. [very optional] Sampling shadows, midtones and highlights (aka black, grey and white points)
* It's too long to explain. E.g. I can make color adjustments selectively (kind of) of make it locally based on the sampled tone/color.
The new Curves tool reminded me of the Curvemeister plugin for PS. Maybe watching this video is a fastest way to explain what I mean.
P.S. At 1:30 of that video the guy makes some wrong assumptions about PS curve tool.
Actually, the CC version of PS has some added functionality.
This is odd, because the video is dated April 2014 and CC version was around for almost a year back then.
PostPosted: Sun Oct 12, 2014 4:15 am  (#15)
1. Adding new curve point from the image is indeed a very good idea, I'll add it (right button probably).
2. Press key 'R' on the curve window to reset a curve. This is already implemented.
3. Click with right mouse button on a control point to delete it. This is also already implemented :)
PostPosted: Sun Oct 12, 2014 5:15 am  (#16)
Amazing David, thank you
PostPosted: Sun Oct 12, 2014 3:48 pm  (#17)
awesome! thanks!
PostPosted: Tue Oct 21, 2014 4:48 am  (#18)
This is really great! Thanks!
But i've got a problem. I'm still on Windows XP (Professional SP3). Probably that's to blame for the error i get after clicking OK (png-image, colorspace Lab).
*** Error in ./gimp_curves_interactive/*if/../*if/*thread0/*local/rgb2lab8/ *** Command '-rgb2lab': [instance(504,756,1,1,06D40020,non-shared)] gmic<float>::RGBtoXYZ(): Instance is not a RGB image.
This doesn't happen all the time. Sometimes the filter works with a fresh opened GIMP. Sometimes it doesn't.
(Sorry if this is not the right place to post this)
Michael
PostPosted: Tue Oct 21, 2014 12:54 pm  (#19)
Maybe your png has an alpha-channel ?
This should not be a problem anyway, but I'm just trying to guess :)
PostPosted: Tue Oct 21, 2014 1:17 pm  (#20)
Yes, it has. With removed alpha channel it works like a charm.
