It is currently Wed Aug 12, 2026 7:07 am
 Post subject: Irregular reslts from extrude3d filter
PostPosted: Mon Oct 27, 2014 1:32 am  (#1)
I am trying to use the extrude3d filter in a script but the output from the filter is uneven depending on my text length the font size can also have an effect but I set it to 250 on all examples below
                  "-gimp_extrude3d "
                                (number->string 3d-height) ",512,0.6,"
                                (number->string txt-width) ","
                                (number->string txt-height) ",0.88,"
                                (number->string x-angle) ",0,0,45,0,0,-100,0.50,0.70,4"
 Post subject: Re: Irregular reslts from extrude3d filter
PostPosted: Mon Oct 27, 2014 8:00 am  (#2)
I'm not sure I understand your problem Graechan, what would you like to get exactly ?
Those images look good to me.
