It is currently Wed Nov 25, 2026 10:54 pm
 Post subject: Gimp+G'MIC : sharing outcomes on photo transformations
PostPosted: Tue Nov 11, 2014 9:51 am  (#1)
My first contribution on this category (applying artistic effects)
Original here (one of my summer photos):
Transformed image:
obtained by applying Garagecoder's "Aurora" (default parameters: 6,1,0) on a new layer
setting layer mode to Overlay 100%
duplicating the "Aurora" layer
reducing opacity to 90% (keeping Overlay mode)
 Post subject: Re: Gimp+G'MIC : sharing outcomes on photo transformations
PostPosted: Tue Nov 11, 2014 10:27 am  (#2)
my second contribution
original here (one of my summer photos):
transformed into:
obtained by:
- applying David's filter Gradient Norm on a new layer (default parameters)
- setting layer mode to Difference
PostPosted: Tue Nov 11, 2014 12:25 pm  (#3)
That is very interesting, I'll try your steps on my photos. Thanks :coolthup
PostPosted: Fri Nov 14, 2014 6:11 am  (#4)
another experiment
original
modified
1-black crayon graffiti on a new layer (active)
2-mode to "difference"
3-new layer from visible
4-mode to overlay
PostPosted: Fri Nov 14, 2014 6:30 am  (#5)
I tried your methods on this photo. I changed the layer mode, too. I like because it gives an original look to the photos. :)
PostPosted: Fri Nov 14, 2014 6:37 am  (#6)
yes, Gimp-G'MIC is like a treasure island, you have to explore it!
PostPosted: Fri Nov 14, 2014 8:52 am  (#7)
another attempt, with one of my favs: Psychedelic Glasswork
original image
creating a new layer using psychedelic glasswork then mode=multiply
same as above, but using mode=overlay
PostPosted: Fri Nov 14, 2014 9:01 am  (#8)
another again
used watercolor on top, then multiplied
look how this filter can be used to improve dramatically the details of thye photo!
original
modified
PostPosted: Fri Nov 14, 2014 9:47 am  (#9)
Absolutely right! These steps give the photo a lot of enhancement. My try
PostPosted: Fri Nov 14, 2014 10:12 am  (#10)
yeah, edges are much better defined...
PostPosted: Fri Nov 14, 2014 10:56 am  (#11)
never look at outcomes generated by GMIC-isophotes?
interesting!
here Alicia and her dog-friend (using 16 as parameter)
PostPosted: Fri Nov 14, 2014 3:40 pm  (#12)
Original:
Filtered:
I duplicated the original, apply repair-> smooth bilateral on the copy.
I made 3 copy the filtered layer.
The copy on top is for the contours ->contours->gradient norm, checked "negative colours". I coloured the contours with curves (usually I make them blue, this time I preferred a dark yellow). Layer on multiply, opacity near 50%.
The middle one ->testing -> Corvo's painting. XD. Layer mode normal, opacity near 50%.
The bottom copy -> contours, segmentation.
Merged the middle and bottom copies, played with curves on the merged layer (rgb curves and hsl).
Added a texture ->pattern -> canvas texture with a low amplitude.
PostPosted: Fri Nov 14, 2014 3:48 pm  (#13)
I like that Corvo. It seems you have transformed the photo in a beautiful painting. :bigthup
PostPosted: Fri Nov 14, 2014 3:50 pm  (#14)
interesting!
Yes, it is very interesting your outcome. I like it a lot. :bigthup
PostPosted: Fri Nov 14, 2014 7:07 pm  (#15)
I tried this image.
PostPosted: Sat Nov 15, 2014 5:42 am  (#16)
it looks very good, Wallace!
you didn't say using which filters, did you?
PostPosted: Sat Nov 15, 2014 6:32 am  (#17)
Hope you don't mind me cheating. Though I did a lot of G'MIC bilat smoothing for cleaning (also used Wavelet Denoise filter which is not G'MIC), I also used some other things (to darken the sky, I used Unplugged's Ink Rubber set to value; this is a filter factory filter which I used the User Filter for run). Also, selectively saturated the reds. Forgot to add that I also first dupped and ran Luma Invert filter set to overlay for a contrast mask. :)
PostPosted: Sat Nov 15, 2014 6:38 am  (#18)
OK; this time I mainly used G'MIC. lol
Used Fast Tone mapping then hyper saturated. :)
PostPosted: Sat Nov 15, 2014 7:00 am  (#19)
Welcome here Lyle!
Very interesting outcomes.
Should I assume you like my photos as a base for your experiments or ... is it just a case!? hehehe...
PostPosted: Sat Nov 15, 2014 9:37 am  (#20)
I do like your photos but also, I have no good photos of my own. lol
