It is currently Fri Aug 14, 2026 3:54 pm
 Post subject: Upgrade
PostPosted: Fri Jan 02, 2015 11:21 am  (#1)
Hello you all,
This is really a dummy question : how to upgrade G'MIC on GIMP / Linux (64b) ?
I've checked Readme, forum, etc... It seems obvious to all and I feel really left out :oops:
 Post subject: Re: Upgrade
PostPosted: Sat Jan 03, 2015 6:05 am  (#2)
Until someone with Linux lets you know how you could use the online version
https://gmicol.greyc.fr/
PostPosted: Sat Jan 03, 2015 8:02 am  (#3)
isnt there a circular arrow that you can click when G'Mic is open which updates it
PostPosted: Sat Jan 03, 2015 8:12 am  (#4)
If you need to update the actual gmic file the only way is download and replace.
download from here
http://gmic.eu/
unzip and copy/replace the gmic_gimp file to your ~/gimp-2.8/plug-ins
It should already be marked as executable, but check anyway.
PostPosted: Sun Jan 04, 2015 2:01 pm  (#5)
Thank you rich005,
The pb is that ~/gimp-2.8/plug-ins is not writable. There should be a command line instead of drag & drop. I need to check that.
PostPosted: Sun Jan 04, 2015 2:21 pm  (#6)
pierpiotr wrote:
Thank you rich005,
Oh dear,
Remember your gimp profile is a hidden folder and you need to enable hidden in your file manager.
Also ~/.gimp-2.8/plug-ins is in your home directory and is owned by you with read/write permissions.
If you can not copy there with whatever file manager you are using then you have a big problem.
Did you possibly install the existing version either from your package manager (synaptic or maybe gdebi or ...) or maybe using the gmic deb package? where you have to be root?
