It is currently Thu Aug 13, 2026 3:30 am
 Post subject: Guesss the filter
PostPosted: Sun Apr 26, 2015 2:16 pm  (#1)
What filter was used?
 Post subject: Re: Guesss the filter
PostPosted: Sun Apr 26, 2015 2:53 pm  (#2)
Ellipsionism?
PostPosted: Sun Apr 26, 2015 3:38 pm  (#3)
Frequencies>Bandpass ?
PostPosted: Mon Apr 27, 2015 3:04 am  (#4)
As seen through several bottles of Amstel ;)
PostPosted: Mon Apr 27, 2015 3:51 am  (#5)
three guesses (G'MIC), among which to choose:
1-Deformations: textured glass, using low values and smoothness
2-Deformations: ripples, using low values on the image rotated 90°
3-Testing/Naggobot: warp test
PostPosted: Mon Apr 27, 2015 5:39 am  (#6)
Lyles Painting
PostPosted: Mon Apr 27, 2015 6:44 am  (#7)
OK, that was a trick question :) No filter involved, it is exactly as it came out of the camera. Boat was half a (nautical) mile away, shot with a 400mm lens, and likely some haze/light mist in between.
@rich: more likely Britt, Lancelot, or Coreff, given where this was shot :)
PostPosted: Mon Apr 27, 2015 6:50 am  (#8)
nice trick, Ofnuts!
