It is currently Mon Aug 10, 2026 3:09 pm
 Post subject: GMIC hanging up on startup
PostPosted: Sun Mar 06, 2011 1:55 am  (#1)
Just as a point of information, every time I start Gimp I get a window like the example I included. Then Gimp just sits there until I close the window. It doesn't cause any problems, I just thought that it might be worth mentioning in case the developers need to know. BTW I use gimp 2.6.11 and I'm using GMIC 1.4.8.2
 Post subject: Re: GMIC hanging up on startup
PostPosted: Sun Mar 06, 2011 5:16 am  (#2)
This is not an error.
http://www.flickr.com/groups/gmic/discuss/72157625763559209/
If you are not using command line users running it from Bash delete file: gmic_bashcompletion.exe
