It is currently Sun Aug 16, 2026 4:42 pm
 Post subject: Release of G'MIC 1.6.5.1
PostPosted: Tue Jul 21, 2015 10:52 am  (#1)
Hi Folks,
I've released today a new version of the G'MIC image processing framework, including the plug-in for GIMP.
You can get the full changelog here : https://discuss.pixls.us/t/release-of-gmic-1-6-5-1/284
Download the plug-in for GIMP at : http://gmic.eu/gimp.shtml
I hope you'll enjoy this upgrade.
Have a nice holiday !
 Post subject: Re: Release of G'MIC 1.6.5.1
PostPosted: Tue Jul 21, 2015 11:35 am  (#2)
I don't know about anyone else, but I can never find the download place. It would be nice if that was posted along with the new releases.
Thanks David for the new upgrade wherever it may be. :bigthup
PostPosted: Tue Jul 21, 2015 11:46 am  (#3)
Thanks O, I've added the link to download the plug-in.
PostPosted: Tue Jul 21, 2015 12:03 pm  (#4)
PostPosted: Tue Jul 21, 2015 12:16 pm  (#5)
Thank you David
PostPosted: Tue Jul 21, 2015 12:30 pm  (#6)
Is it required/necessary that I uninstall my previous version of G'MIC?
PostPosted: Tue Jul 21, 2015 12:35 pm  (#7)
Wallace, when you put in a new update, it will replace the previous one.
PostPosted: Tue Jul 21, 2015 12:48 pm  (#8)
Thanks Molly.
I'm pretty sure if I uninstall the previous version and install the new one, this would be okay as well.
I'm guessing that it probably doesn't really mater either way. It does however take a few more clicks then just running the new Windows gmic.exe file.
PostPosted: Tue Jul 21, 2015 12:49 pm  (#9)
Either way will do it.
PostPosted: Tue Jul 21, 2015 12:51 pm  (#10)
PostPosted: Tue Jul 21, 2015 2:22 pm  (#11)
I always bypass the installer and just replace the actual .exe file. Simpler for me that way. :)
