It is currently Fri Nov 27, 2026 5:06 am
 Post subject: ZArt for Win_32 (Release Candidate)
PostPosted: Sun Aug 02, 2015 7:39 am  (#1)
Continuation thread:
http://gimpchat.com/viewtopic.php?f=9&t=12827
Probably not beta.
https://www.dropbox.com/s/62x2726ylagmuyr/ZART%203%20for%20Win_32.ZIP?dl=0
David - please take care of downloadable from your site.
ZArt = 3.0.1 (264 preset)
GMIC = 1.6.5.0
gcc++ = 4.9.2 https://msys2.github.io/
QT = 5.4.2 (for Pacman)
 Post subject: Re: ZArt for Win_32 (Release Candidate)
PostPosted: Thu Mar 09, 2017 4:30 am  (#2)
Zart 3.2.1
https://github.com/dtschump/gmic-community
Developers:
- Sebastien Fourey: Project manager / GUI Programming
- David Tschumperle: G'MIC scripts
Just for fun my new compilation using MSYS2 GCC 6.1.0 QT 5.6.1
Download: Zart-3.2.1_32bit.zip (zip: 29 427 635 bajt, unzip: 74 284 477 bajt):
https://www.dropbox.com/sh/gzklccg29vyknrt/AAA3KV-h_Bfb-VdMZUcaZPBva?dl=0&preview=Zart-3.2.1_32bit.zip
Some news:
- Secondary windows
- Faves
Unfortunately - the inability to save the processed file - only the screenshot.
PostPosted: Thu Mar 09, 2017 6:03 am  (#3)
Thanks MareroQ, I'm planning to support the Windows build of ZArt also from my side soon !
(at least for 64bits systems).
EDIT: I confirm, I've just succeeded in compiling ZArt under Windows, seems to run fine so far.
I'll provide binary packages for ZArt on Windows tonight probably.
PostPosted: Thu Mar 09, 2017 9:07 pm  (#4)
how should 'Zart' be Installed, as I'm getting error messages (about a missing Qt platform) when I start gimp
Where can I find this missing platform
PostPosted: Fri Mar 10, 2017 12:55 am  (#5)
Hi Graechan.
It is already available version gmic_zart_win32 / 64.zip.
http://gmic.eu/files/prerelease/
Which version results in an error?
PostPosted: Fri Mar 10, 2017 2:07 am  (#6)
I set my preferences to the unzipped 64bit version, (downloaded from gmic.eu) my gimp is 64bit installed on a win10 computer
I have a 32bit portable gimp that i will try with the 32bit ZArt tomorrow morning
PostPosted: Fri Mar 10, 2017 7:16 pm  (#7)
the 32bit version is a no go as well it say's I,m missing certain win platforms :gaah
PostPosted: Fri Mar 10, 2017 8:13 pm  (#8)
I downloaded a 32bit version of ZArt 3.2.1 from MareroQ Here and ZArt fired up nicely :bigthup
